a/c line installed, alternator back in, metal removed for clearance, brackets and pulleys installed.
I put the new ac line with little issue, like I said dropping the sway bar and removing the electrical connections and coolant lines is the way to go about getting this line in and out. that being said I had a fuck of a time getting the coolant lines back on the the back of the alternator. dropping the subframe would have allowed for more room to do this but a little patience and some long needle nose and I got the line on. I also got rid of the spring clamp and went with a gear clamp, if u use 4 extensions u can sneak the socket in there and tighten the clamp fairly easily, so fuck u spring clamp
I did all my clearance cutting and forgot to take a pic. looking at the sc mounted and the room behind it I was finding it hard to believe the intake hose is going to fit but after a few measurements its looking good. I did cut a larger hole than needed because I had a few ideas of how to make it look prim and proper kind of like how sar welded in his cuts. I still haven’t wired the garage with a 220 plug so for now im just gonna leave it open.
oh and the alternator is ridiculously tight against the frame rail, I couldn’t get it out without making a small bend in the lip on the bottom of the frame rail so while I had the zip disc on I cut about 3/8 of an inch off the bottom of the frame rail lip. this made installation of the alternator a shit ton easier and it allows just a bit more clearance for the coolant line.
installing the brackets and pulleys was very straight forward. looks mint and strong as hell. I need to install the clamp supplied with the kit to keep the wires away from the charger and mock up the rest of the lines to ensure theres proper clearance for everything and then permanently install the charger. gettin close!!
http://i1270.photobucket.com/albums/jj615/Garrett_Hargreaves/Mobile%20Uploads/20141212_232144_zpslyookrle.jpg
http://i1270.photobucket.com/albums/jj615/Garrett_Hargreaves/Mobile%20Uploads/20141212_232135_zps3lr9pblz.jpg
http://i1270.photobucket.com/albums/jj615/Garrett_Hargreaves/Mobile%20Uploads/20141212_232118_zps5gng7yi4.jpg
but unlucky for me she loves driving
jk cant wait to see some videos numbers and stuff!
