Recently, I’ve been getting a code for one of my o2 sensors. So I did some googling on the code(s) and found a suggestion to check the connections. So what I did was clean them up with a cleaner for electronics I had, waited till they dry and plugged them back in.
Then I also did a throttle body adaptation via vag-com.
After starting the car and pulling it around the back of my house, I noticed a weird idle. So I took for it a spin around the block and the car seemed like it was about to stall when I stopped. The idle is rough.
But what I also noticed is that I’m getting a sound that seems like a ball bouncing around in an empty can?
You can hear it in the following video:
http://s114.photobucket.com/albums/n245/Coderedpl/?action=view¤t=VID_20120531_122947.mp4
All i have are piggies, magnaflow catback, JHM tune and K&N filter
I’m still under CPO warranty, should I be concerned?
EDIT: I went back out to the car, scanned it more, and for shits and giggles ran through all the output tests. Shut it off, restarted, took it for a drive and it seems OK? It seems that I heard the sound one more time afterwards but the car seems to idle fine now? WTF?!
EDIT #2: Everything is back
