BlackS6's build
Makes the car look newer and sportier. Nicely done
Thanks man I love the car so might as well upgrade to the new stuff so I don’t have to upgrade to a new car although the RS7 is tempting
Here’s a part listings to make the harness for the 3G installation translated from German
Conversion from MMI 2G to MMI 3G (Audi A6 4F)
Modification of the complete infotainment system from MMI 2G to MMI 3G (3D hard drive navigation).
HIFI HARDWARE
Control unit:
1x 4F0919604 - 7 "MMI 3G Display unit (display)
1x 4F1919611S - MMI 3G Control unit Left-hand drive with joystick
1x 4F0035061 - MMI 3G radio incl. DAB
1x 4E0035670 - MMI 3G Headunit with hard drive and Bluetooth Carphone
1x 4F0035223P - Bose Amplifier Avant)
1x 4F0907441D - Control unit reversing camera (Avant)
1x 4F0920932S - Combination instrument (3.0TDI incl. ACC)
1x 4L1035711C - Bose Microphones for interior
lighting Antenna Amplifier:
MMI 3G Radio High with all options - TV, Telephone, Heating, DAB
4F9 035 225 AA - Antenna amplifier rear left
4F9 035 225 AJ - Antenna amplifier rear right
4F9 035 225 AC antenna amplifier rear door left
4F9 035 225 AF antenna amplifier rear door right
4F9 035 225 AM - Antenna amplifier right C - Column
small parts:
1x 4F0907368A - Mounting for control unit left rear
2x N 90342504 - snap nut rack
4x N 10710501 - hexagon socket rack
1x 4F0907348 - spacer rack
10 x N 90486102 - Hexagon nut
for amplifier
2x N 10082908 - Snap nut for amplifier
3x N 90777704 - Snap nut for amplifier
1x 4F0035909 - Holder for AMI plug in glove compartment
3x N 10599501 - Screw for amplifier
2x N 90342504 - Snap-on nut For amplifier holder
1x 533867910A - Felt strips for amplifier connectors
and pins:
Facelift CAN Gateway:
1x 8E0972420 - Connector for 3G CAN Gateway
8x 000979009E - Pins for CAN Gateway 0,5mm² (number depends on equipment - 16 pins with maximum equipment)
MMI 3G Display:
1x 4F1971086A - line display -> MMI 3G Head Unit
1x 3D0972708 - plugs display (current)
1x 000979009E - pins for power supply (0.5 mm²)
1x 000979133E - pin for fuse holder (small fuse) (1 pin required)
MMI 3G Head Unit (plug ’ N’Play adapter see below!)
1x 8Z0972112 - 12 pin connector housing for the original pins of the 2G interface (connector A)
1x 4F 0972112 - 12 pin mating connector
4x 000979012E - Pins for mating connector
1x 3M7035444 - Quadlock connector for MMI 3G headunit
1x 000979225E - Pins for power supply Quadlock connector (2,5mm²) (to be connected directly to grounding point / fuse!)
1x 000979227 - Pin for fuse holder (large Fuse, 2.5mm²) 1 pin required
4x 000979021E - Pins for Quadlock connector (0,5mm²)
1x 3B7035447 - Connector in Quadlock MMI 3G Headunit 8 pin brown
1x 3B7035447A - Connector in Quadlock MMI 3G Headunit 12 pin blue
2x 4E0035602K - FAKRA Antenna lightblue (FBAS, GPS)
1x 4E0035674K - FAKRA Antenna lightblue (telephone)
1x 4F1971086B - Cable Music Interface from MMI 3G Headunit
1x 8L0972623 - 2-pole mating connector for Bose microphone plug on the original cable harness incl. Pins
1x 6Q0972706 - 6 (T6ao) for 3G microphone unit
6x 000979009E - Pins for blue plugs at the microphones and for blue plugs at 3G Headunit (0,5mm²)
1x FAKRA plug (male) with Lei tung piece Reverse Camera Adapter
MMI 3G Radio: (Plug’n’Play adapter see below!)
1x 3B0972734 - counterpart to original plug
1x 000979254E - pins for power counterpart to the original connectors (1,5mm²)
1x 000979020E - Pins for counterpart ring break diagnosis to original plug (0 , 5mm²)
1x 4E0035444 - quadlock connector 3G radio
1x 000979243E - pins for power supply Quadlock connector (2,5mm²)
1x 000979021E - pin for ring break diagnostics Quadlock connector (0,5mm²) - 1 pin required
1x 4E0035672K - FAKRA connector antenna Analogradio 2-way Light blue
1x 6Q0035576K - FAKRA connector antenna DAB light blue
BOSE amplifier:
plug and pin assignment identical!
MOST bridges:
3x 4E0972645 - Connector for optical fiber (bridge for MOST bus from MMI 2G Interface, Navi and 2G Bluetooth control unit)
PINBACKS
CAN Gateway:
2G CAN gateway
3G CAN Gateway
T26a / 1 (red / blue)
T20p / 1 (terminal 30)
T26a / 2 (red / blue) -> not applicable
X
T2bc / 1 BEM (new) and D + alternator
T26a / 3 (gray / black)
T20p / 13 (KI wake-up line T32 / 28)
T26a / 4 (green / purple)
T20p / 10 (ring fracture line)
T26a / 6 (orange / green)
T20p / 15 (CAN T46b / 10H)
T26a / 8 (orange / black)
T20p / 16 (CAN T46b / 2H)
T26a / 9 (orange / blue)
T20p / 18 (combination instrument T32 / 4)
T26a / 11 (orange / red)
T20p / 19 (OBD pin 6)
T26a / 13 (orange / black)
T20p / 17 (ACC pin 2)
T26a / 14 (brown)
T20p / 11 (mass)
T26a / 15 (brown) -> not applicable
X
T26a / 16 (black / white
T20p / 14 (terminal 15 fuse SC8 5A)
T26a / 19 (orange / brown)
T20p / 5 (CAN T46b / 10L)
T26a / 21 (orange / brown)
T20p / 6 (CAN T46b / 2L)
T26a / 22 (orange / brown)
T20p / 8 (combination instrument T32 / 3)
T26a / 24 (orange / brown)
T20p / 9 (OBD pin 14)
T26a / 26 (orange / brown)
T20p / 7 (ACC pin 3)
When the alternator is renewed: T20p / 2 (3G CAN gateway) -> T2bc / 1 (BEM) and D + (Lima)
MMI 3G display:
source
MMI 3G display main connector
Terminal 30 Fuse SB22 5A
T8ac / 4 (terminal 30 display)
Dimensions
T8ac / 5 (mass display)
MMI 3G Headunit:
MMI 2G interface main connector
MMI 3G Headunit Quadlock
A6 (white / yellow)
T8y / 3 (operating unit)
A7 (red)
T8y / 2 (operating unit)
A8 (brown / blue)
T8z / 16 (operating unit)
A13 (green / blue)
T8y / 6 (operating unit)
A14 (green)
T8z / 14 (operating unit)
A15 (green / gray)
T8z / 11 (operating unit)
A16 (white / gray)
T8z / 10 (operating unit)
A3 (green / purple)
T8y / 7 (ring fracture)
A1 (red / blue) (0.5mm²!)
T8z / 15 (1.5²) (terminal 30 fuse SC10 7.5A)
A2 (brown) (0.5mm²!)
T8z / 12 (1.5²) (mass)
! Cables for T8z / 12 and T8z / 15 must have a cross-section of 1.5mm² - re-attach of ground point or fuse!
MMI 2G phone holder in MAL
T12u / 10 (white)
T8z / 9 (signal mobile phone ON of holder phone R126)
MMI 2G reversing camera
MMI 3G Headunit Quadlock (blue connector)
FAKRA Cable RFK (-)
T12ac / 5 (RFK signal FBAS-)
FAKRA Cable RFK (+)
T12ac / 11 (RFK signal FBAS +)
Microphones in interior light
T6ao / 1 (green)
T12ac / 8 (microphone left plus)
T6ao / 2 (black)
T12ac / 9 (microphone left ground)
T6ao / 5 (white)
T12ac / 2 (microphone right plus)
T6ao / 6 (black)
T12ac / 3 (microphone right ground)
Antenna cables
MMI 3G headunit antenna inputs
FAKRA blue (navigation device)
FAKRA blue (from Navi forward)
FAKRA red (telephone holder)
FAKRA red (put from phone to the front)
FAKRA green (TV tuner)
FAKRA green (composite input - re-install)
MMI 3G radio:
MMI 2G radio
MMI 3G Radio Quadlock
T8p / 1 (brown)
T10ao / 17 inner pin (ground)
T8p / 2 (red / blue)
T10ao / 18 external pin (terminal 30 fuse SF5 5A)
T8p / 5 (green / purple)
T10ao / 11 (ring fracture)
MMI 3G Bose:
Pin assignment on the amplifier identical to the MMI 2G!
Microphone in interior light 2G
Microphone in interior light 3G
T2n / 1 (white)
T6ao / 3 (Bose Microphone Plus)
T2n / 2 (brown)
T6ao / 4 (Bose microphone mass)
SAFETY CHANGES
Security Fuse holder modification
SB16 SB (switchboard left) 5A instead of 10A (only power supply for mobile phone holder in MAL)
SF7 ST2 (brown) trunk Not applicable (navigation unit in trunk is not required)
SF9 ST2 (brown) trunk Not applicable (separate DAB control unit not required)
SC10 ST1 (black) front right 7.5A instead of 5A (MMI 3G headunit)
SB22 SB (switchboard left) In addition: 5A, terminal 30 (MMI 3G display)
MOST ring
MMI 2G:
CAN Gateway -> MMI 2G Interface -> CD changer -> Phone -> Bose amplifier -> Radio -> TV Tuner -> Navi -> DAB
MMI 3G:
CAN Gateway -> MMI 3G Head Unit -> CD Changer -> TV tuner -> radio -> Bose amplifier
PLUG’N’PLAY ADAPTER CABLE
MMI 3G CAN Gateway:
8x 000979009E - Pins for CAN Gateway 0.5mm² (number depends on equipment - 16 pins with maximum equipment)
Option 1 (solder):
Pins from 2G CAN gateway, 009E. Thereafter einpinnen in new connector according to
section “pinouts / CAN gateway”
: - possibility (100% deinstallation modify plug) 2
Green Pinträger from the 2G CAN GW plug cut (of 26 slots to 20 slots) and the green carrier so
that it edit, Can be inserted into the new 3G CAN GW connector. Pn into the modified 2G carrier
as described in section “Pin assignments / CAN gateway” and insert the carrier into the 3G connector.
MMI 3G radio:
1x 000979254E - pins for power supply counterpart to original plug (1,5mm²)
1x 000979020E - pins for ring break diagnosis counterpart to original plug (0,5mm²)
1x 4E0035444 - quadlock plug 3G radio
1x 000979243E - pins for Power supply Quadlock connector (2.5mm²)
1x 000979021E - Pin for ring fracture diagnostics Quadlock connector (0.5mm²) - 1 pin required
Install adapter according to section “Pin assignments / MMI 3G radio”
MMI 3G Headunit:
1x 8Z0972112 - 12 pin connector housing for the original pins From the 2G interface (connector A)
1x 4F0972112 - 12 pin mating connector
4x 000979012E - pins for mating connector
1x 3B7035444 - Quadlock connector for MMI 3G headunit
1x 000979225E - Pins for power supply Quadlock connector (2,5mm²) (directly to ground point / fuse)
3x 000979021E - Pins for Quadlock Connector (0.5mm²) - 5 Pins required
1x 3B7035447 - Connector in Quadlock MMI 3G Headunit 8-pin brown
2x 000979 021E - Pins for brown
quadlock connector (0.5mm² ) 1x 3B7035447A - Connector in Quadlock MMI 3G Headunit 12 pin blue
3x 000979009E - Pins for blue Qudlock connector (0.5mm²)
Adapter according to section “Pin assignments / Headunit / MMI2G-3G” assemble
(Only pins from 2G interface plug & Play are involved - the rest has to be soldered.
Microphone adapter:
1x 8L0972623 - 2-pin connector for Bose microphone plug at the original cable tree incl. Pins
1x 6Q0972706 - 6-pin connector blue (T6ao) for 3G microphone unit
5x 000979009E - Pins for blue plugs at the microphones and for blue plugs at 3G Headunit
from 8L plugs from two cables with one 009E pin each on the other side.
4 leads with 009E pins on both sides (from mics in the roof to 3G Headunit).
Pin connector, please refer to section “Pin assignments / Bose” anyway “Pin assignments / 3G Headunit / Microphones”
Reverse camera adapter:
1x 000979009E - Pins for blue MMI 3G Headunit connector
1x FAKRA connector with lead (male)
FAKRA line insulation and a pin 009E to the shielding compound and a Pin 009E to the inner
conductor solder pins 009E in blue connector to MMI 3G headunit (Pin assignment according to “Pinbelegung / Headunit / RFK”)
Telephone adapter cable:
1x 000979009E - Pin for telephone holder (1 pin required)
1x 000979021E pin for T8z / 9 MMI 3G Headunit
1 Line with one pin 009E on one and one pin 021E on the other side (from telephone holder to MMI 3G headunit)
According to the section “Pin assignments / headunit / telephone”.
Display adapter (current):
1x 3D0972708 - connector display (current)
1x 000979009E - pins for power supply (0.5mm²)
2 leads with pins 009E on one side and pin 135E (positive) or cable shoe (earth) Connect / connect according
to section “Pin assignments / display”.
Is the Rs6 front bumper a direct bolt on?
I like older cars with soul, get the tech up and remove temptation. Rs7 u have to do triple digits to break a sweat, not quite as fun. More fun to drive. Slow car fast, then a fast car slow :slight_smile:
It is relatively a direct bolt in there will need to be some fender work if you don’t get the rs6 fenders
You have a good point lol most of my fun cars were slow that I pushed the limits of
It’s why I own a '68 Porsche 911 (not necessarily slow though :wink: ) It’s a 2400 lb. short wheel base go cart that is challenging to drive well at 8 or 9 tenths. There’s no way the S6 or any similar modern car would be anywhere near as fun to drive in everyday situations.
I like the V10 S6 because its a well-built, comfortable car that I find interesting and enjoyable for daily commuting. The expensive mods go to the “other” car that’s more deserving IMHO.
Finally got around to installing the tune and all I have to say is “this will be fun” initial impression is smooth shifts and continuous power parked it for a bit and punched it to get on the highway and it took me by surprise for sure !
that tune is the business… I wish I could flash back to stock and then back to tuned at least once more; it’d give a cleared picture of what the tune does and how driving behavior changes. I also wish I could change the shift points in the TCU. : /
You can… if you go to Michigan or Cali for the TCU tune. I was planning on going north soon, but this tire issue has set that back a bit.
Hey they both deserve love ;). Your second paragraph is spot on, that said if you do the minimal mods to the s6, it truly is truly how it should have come from the factory. That said I loved my last stock one with msds filtered and true 2.75 x pipe exhaust even with stock mufflers! The exhaust is a must if you ditch all else, less so on s8 :wink:
Hmmm - I’ll have to call 'em. I bought the cable and loaded the tune myself; maybe I can get em to mod mine?
Speaking of the tune I’ve noticed something, not sure If its the tune or maybe my injectors might be leaking. I noticed that shift from 1st to 2nd I reach some sort of fuel cut at the top of first during the shift then it goes into second this only happens if I’m hard on it… not sure also it is the TCS cutting fuel for traction.
The tune makes the injectors match modulation in pedal travel exactly apparently… especially in sport mode… for me, there’s a clear cut between 1st and 2nd when I’m at like 40% throttle that sounds amazing like you can here the pressure difference in the exhaust. but yeah, when track driving you notice it even more (especially in sport) where if you let off the throttle, you hear a clean cut in fuel delivery, or at least that’s what it sounds like to me (someone without any mechanical training).
Six6six thats a great explination. The JHM tune does exactly that. The injectors, camshafts, ignition and throttle body all work directly in line with the throttle in put so the result is full control. But what lots of people dont know or dont talk about is just how much work on the little things JHM has put into things like the transmission protection and the tighter control of the injectors to not just help keep the car more crisp and controled but it helps keep the transmission happy and safe along with the bennifit of using less wasted fuel.
It’s the efficiency and performance paradigm right in the cross hairs with the JHM Tune.
Really is the number one mod closely followed by a nice 2.75 exhaust especially if an s6.
that exhaust valve timing overlap making that big ole’ blatty exhaust reversion on upshift is tits, ain’t it?! There’s no sound like it…
::LOVE::
Hell yeah it is !!
