Great. I wonder if there’s a business for this package? A lot of people in those Facebook Audi 4f/c6 groups lol
https://uploads.tapatalk-cdn.com/20170715/a1c6730e1c8e0c5ec49c4583b72248c0.jpg
I got it to work not as hard as i thought wooohooo
Sent from my iPhone using Tapatalk
Great work. Excited to hear more. Might even be worth its own thread with a good walk through
This is interesting! I just want to get my iphone connected for music but this is great.
You going to do a write up?
I’m going to try to do a write-up
I’m also going to try and create a plug and play kit for those that want to do the same thing.
By the way… i have a 2g AMI kit for sale lol
PM
Also 3G+ unit has arrived so I’ll have a spare 3G unit for sale as well.
https://uploads.tapatalk-cdn.com/20170723/64aaf3078e784961c0fdec42b32a6d13.jpg
Just a little picture of my dash with component protecting finally removed everything works !!
Great build!
So, how would a display and the controls fit in our cars? From this (https://en.wikipedia.org/wiki/Multi_Media_Interface), it looks like a 3G+ display is larger and the controls are smaller.
The display doesn’t beee either be replaced from the 3G+ only 3G+ unit and 3G controls if you didn’t already switch when converting from 2G
aaaaaawesome news!! The 3g+ display is WAY better! Another project to start collecting parts for!
2008_S6:
Ok, I will wait for the write up so I can understand better. Can you give us a ballpark of the cost to get from the base set-up (I assume my '08 is 2G) to a 3G+? Also let us know if new or used parts were used? Thanks for all the info and documentation you have provided.
BlackS6:
2008_S6:
Same question… Going to eventually need a parts list to start collecting lol
I used all used parts …I literally had it ripped out of wrecked a6 turn had it coded
Mmi unit
Gateway
Mmi control
Bose amp
And interior harness if you can get it
You’ll need additional 6m blue fakra cable
And another cable for the radio
If you get the harness you can pair the wires so you don’t have to have the pins and crimp them if not you have to get the pins
The parts and part numbers are listed further up in this thread as are the instructions I used
Mmi unit
Gateway
Mmi control
Bose amp
The parts and part numbers are listed further up in this thread as are the instructions I usedSent from my iPhone using Tapatalk
Thanks for all your work on this. A write up would be great.
So what could this be ?! I’m getting tired of every time I turn around I have to fix a major issue with this car
https://uploads.tapatalk-cdn.com/20170920/ecc0c3cdd1fdfa3b5677d8f1f8ab2c68.jpg
https://uploads.tapatalk-cdn.com/20170920/1c748f9d477851d1dcd4da92336fcd5f.jpg
https://uploads.tapatalk-cdn.com/20170920/bf1a94d72bd7459f8125df71124e154f.jpg
https://uploads.tapatalk-cdn.com/20170920/bf7bda8ebde96f0e68f136109c0f0bc3.jpg
https://uploads.tapatalk-cdn.com/20170920/3ba9136a9eb62f36751af6f9dcc3210a.jpg
https://uploads.tapatalk-cdn.com/20170920/4904bc953af6c131ade08e85a80e766a.jpg
Lean at idle could mean vacuum leak?
I have a bunch of misfire codes too. Just scanned the car last night. There is a misfire thread started maybe post in there too.
https://uploads.tapatalk-cdn.com/20170926/0ded2eeeb194f90e35dbadffa0ca193c.jpg
Probably the worse thing you can hear after you already replaced the engine and transmission
Umm… warranty? Please? Insurance? GAP?
BlackS6:
Nope no warranty smh …warranty dropped me when engine and tranny was replaced paid off so no gap
