^^ Here ya go. There are other setups and other options, but this is one.
[QUOTE=shiv@vishnu;13835385]Update: PUMP GAS (91oct) NO METH:
Dyno @ http://www.e90post.com/forums/showthread.php?t=829687
Happy to say that we were the first to break 300, 400, 500, 600 and now 700whp with the N54
Captain Insano’s Vishnu/FFTEC 6466 single turbo 335i
100oct+pwm meth
26psi
4th gear
STD corrected
No Smoothing (set to 0)
Full torque by 4300rpm! And a nice linear 700whp @ only 26psi, which suggests that there is plenty left in this 6466 turbo (should support over 850 WHP). The Capt has been running this car at Laguna Seca for the last year (albeit with 50whp less)
Uncorrected/Actual: 708whp 606wtq
Still some fine tuning to do with the WGDC table (it is currently based on the smaller 6262 turbo which isn’t ideal but good enough for this initial testing). The 6466 spools just as quickly as the smaller 6262 but packs a serious punch and absurdly fast spool. Hope to run some 60-130s with it this weekend. And I hope to see 5.x seconds.
Both STD and Uncorrected/Actual results attached below:
http://www.e90post.com/forums/attachment.php?attachmentid=847561&stc=1&d=1366191596.jpg
http://www.e90post.com/forums/attachment.php?attachmentid=847562&stc=1&d=1366191596
I believe they are swapping the springs on the head just to prevent valve-float, but that it’s a minimal build (i.e. not porting or replacing valves).
Saki, any chance that is the same Captain from the early JHM days? Time for you to do some research. Says he’s in the SF area (I dunno where the JHM captain guy was from). If it is him, it’d be cool for him to post his info/perspective over here.
