Yeah it’s too bad you gave up Ryan…I think once you got an even layer of track rubber on your tires, you would have been ok. My PBs have usually been after the 5th run or after.
I’d definitely try my method a few times, back up right to the water box if you have to, shift to M, and spin them hard, then back to S. ATCO made us run through the water box, but they had enough burnout length after that to get the tires spinning on the run up to the staging beams. I’ve never noticed (heard?) any stones on my tires that was significant enough to affect the launch. But I have noticed that my tires tend to grab enough track rubber after 10 runs to affect launching in a positive way. A couple weeks ago, I think Bear had the same thing, his 60’s kept improving, mind you, not to 1.6s…I think a 1.71.
Looks like both those runs would have been 11.9s at least, if you could have pulled a 1.70 60’. Was really sweet watching the 335 disappear in your mirror on the second vid.
