Okay here we go.
I’ve been having troubles with my car since april and I would like some advice on what to do next.
My car has random multiple misfires and misfires on cylinders 1 until 8. They never occured on cylinders 9/10. But only during standstill in D or very slow city traffic everything else goes wonderfull.
This all started after a carbon clean. Before that i’ve never had an engine code.
the whole saga can be found in this thread:
So far: all new gaskets, all new spark plugs, new wire connectors , new HPFP’s, all injectors flow tested and good, carbon cleaned, intake manifold opened and checked (all good), new coil packs, new throttle body manifold, replaced a few vacuum lines.
Result: still intermittend random misfires and misfires on cilinders 1-8
So the engine runs realy smooth, closed valves can hold liquid overnight so no leaks there. No oil consumption… So mechanicaly the engine is just spot on.
This leaves me the conclusion that there may be some fault on the exhaust side since intake side is all checked.
Now the next step is an engine drop for the replacement of all O2-sensors (which don’t have any codes at the moment) without any sign that this will solve anything. Btw i don’t have space to the engine drop myself so i have to pay for the labour
Or… gut the cats from underneath the car and put in a JHM tuning in the hope that this will solve the misfires (If they are cat related). Like this it would save me an engine drop.
But i fear the car will be obnoxiously loud and will drone on the highway.
Note that the car has had some insulation material comming out of the exhaust side of bank 3/4 which I can’t explain. Is there some kind of insulation wool in the cats? If so is it possible that the car has ‘gutted’ cat 4 (cylinders 9/10) already and now throws codes for the other cylinders?
I realy don’t know what to do since this journey has costed me over 4000 euro’s already and i don’t want to pay for an engine drop and O2 sensor change to stay with a car that still throws codes at me. That would drive me nuts.
The car only has ±78k miles with a replacement engine under warrantee at 20k miles.
What would you do?
