This thread will detail my install process and tips for installing the JHM intake manifold spacers. For those that don’t know, the intake manifold spacers act as a barrier between the intake manifold and the help reduce intake manifold heat-soak. Testing has shown a difference of up to 40F.
The Secondary Air Injection system is some silly emissions system that is unnecessary. It will only ever be used to inject additional air into the exhaust system during cold startups. It is safe to delete and JHM can modify your ECU to ignore the codes that will be produced when the system is blocked off. This is completely optional, but I’d recommend to go ahead and do it if you have the appropriate tune.
The throttle body has two small coolant hoses connected to it to allow coolant to flow through it. The purpose is to give additional heat to the throttle body, which is really only useful in cold climates. In warm climates we need to keep as much heat out of the throttle body as possible. Originally I didn’t plan to do this mod, but when I broke off one of the coolant stems at the main coolant pipe it presented the opportunity. An audi mechanic I know said that I might have trouble with idling if I bypassed the TB heater hoses, but I haven’t had a single problem since I did this mod.
Tools needed:
Phillips screwdriver
Flathead screwdriver
Ratchet
10mm socket
Metric hex sockets(I’ll post exact sizes later)
Wobble socket extensions(might be able to get by with regular socket extensions)
Vice grips or hex key needed to remove one of the SAI pipe bolts
Long needle nosed plyers(most valuable tool on this job - because f*** Audi’s hose clamps)
Channel locks(optional - I found it was the easiest way to take off the hose clamps on the air duct accordion tube)
Pry bar(optional)
Supplies needed:
3/4" electric pvc cap(for SAI cap-off)
silicone adhesive/sealant(for SAI cap-off)
2 packs of vacuum tube caps from autozone(for throttle body heater bypass)
2 small hose clamps(for throttle body heater bypass)
2 large hose clamps(optional, but it’s a great idea to replace the hose clamps on the air duct accordion tube)
Disconnect the ground cable from the battery(safety first lol)
Remove your engine covers
Remove air duct
Remove air filter housing
Remove MAF tube and accordion hose
Now is a good time to seal off your air filter housing aka Zingo’s mod if you haven’t done it yet.
Disconnect vacuum hoses, electrical connector, free up crankcase accordion vent hose, and remove screws from solenoid valve retaining plate. It’s a good idea to take a picture of what it looks like before hand so you know how to reconnect everything. BE GENTLE with that accordion hose, it was very brittle on my car with about 70k miles and snapped very easily.
Disconnect highlighted vacuum hose and electrical connector:
Time to pull out the fuel rail and injectors! Bentley manual says to disconnect the electrical harness connectors at the fuel injectors first. I actually found it much easier to pull the fuel rail up first.
Remove the 4 hex head bolts securing the fuel rail.
(If you have a 2002-2003 car)Disconnect the fuel pressure regulator, which is kind of at the back/right corner of the fuel rail.
Use a pry bar or something similar and slowly/gently apply upward pressure to the middle of the fuel rail on one side until the fuel injectors pop out. Repeat on other side.
Now you have plenty of room to disconnect the wiring harness clips.
Once disconnected, flip it over to the left side of the engine bay and cover the fuel injectors with clean rags.
http://i.imgur.com/E0Kzu.jpg
Clean the fuel injectors up before reinstallation.
Above throttle body, disconnect electrical connection to throttle valve control module(1), and vacuum hoses 2 and 3.
Disconnect resonator hose(1) from air duct. Back out the screw(4) securing the air duct to the throttle body and remove air duct. If equipped, disconnect the vacuum hose(3) from air duct.
Now is a good time to go ahead and cap off that resonator connector on the air duct if you haven’t already done it.
Remove the two screws securing the oil dipstick tube(1 and 3) If you plan to remove the SAI pipe, disconnect the plastic accordion hose from the end of the SAI pipe.
Remove the two bolts securing the SAI pipe. The left bolt in the picture has tought clearance. I grabbed my hex socket with a pair of vice grips. You might want to use a hex key.
Remove bolts securing the SAI pipe(1 and 2). Remove bolts securing the resonator(3,4,5) and remove resonator. Don’t reinstall the resonator if you plan on sealing the air duct.
You can go ahead and remove the SAI pipe if you choose to. You’ll want to disconnect the left cylinder head vent tube for clearance and then pry the SAI pipe out of the hose it connects to.
http://i.imgur.com/DD2UF.jpg
Wiggle the SAI pipe out however you figure. I pulled it towards the front of the car and turned it some kind of way. Should look like this when you’re done:
http://i.imgur.com/DBdq7.jpg
Get that 3/4" electric pvc cap(I got mine from Lowes), smear a bit of silicone adhesive sealant around the inside and smash it on that rubber tube. Should look like this when you’re done:
http://i.imgur.com/RAzn6.jpg
This might be different on some cars depending on model year, but on my 2005 BGN motor I had two coolant hoses and two vacuum hoses connecting to the throttle body. The vacuum hoses are fairly easy to disconnect from the throttle body side using long needle nose plyers. Use your long needle nose plyers and make sure the hose clamps on the coolant hoses are fully open before attempting to disconnect them. The stems that extend from the main coolant pipe might be weakened and can snap with little force.
Inspect the spaces around your intake manifold for dirt and grime and vacuum or blow out any that exists. You don’t want that stuff getting into your intake ports.
Remove the 12 bolts securing the intake manifold to the cylinder head and remove intake manifold.
Plug the intake ports with clean rags or rubber gloves while you finish up your other work, sealing the air box/air duct.
If you choose to bypass the throttle body heater:
Get those vacuum hose caps and cap off the two small stems extending from the main coolant pipe. I would use hose clamps on these since there will be some pressure exerted upon them and we don’t want coolant going everywhere. See picture below, blue highlight is where one of the stems used to be until I snapped it. Go ahead and cap off the coolant hose stems on the throttle body side too. You don’t need any additional security, but I zip tied them anyway since I like zip ties.
http://i.imgur.com/XxtVx.jpg
Before reassembly, take time to inspect your intake ports for carbon buildup or any debris that might have fallen in. I had a thin coat of oil around the top half of the intake ports and I was able to clean it off using my fingers. Also go ahead and clean up your intake manifold and fuel injectors.
Go ahead and put your spacers and gaskets on. The gaskets go under the spacers. Other than that they can only fit one way - make sure the bolt holes all match the holes in the spacers/gaskets. The spacers/gaskets will move around a bit when you put the intake manifold back on. I use a 1/4" ratchet extension to insert through the IM bolt holes and maneuver the spacers/gaskets until they were lined up proper.
Put everything back together. Intake manifold bolts get 10Nm or 7.5 lbs. Tighten in a diagonal pattern in stages. I did 7Nm on the first pass then 10Nm on the second pass.
Congrats! You now have a more efficient motor!
Let me know if you have any questions.
