Hi, new here, but i’ve been following for a while.
I have a 2013 FL 4.2 RS5 that’s been fitted with the PES supercharger and running around 600hp and 600nm torque. I’ve not changed anything else on the car and drove for about 12 months without issues and then… all sorts started…
All started from the stock “drive plate/flex plate” not being able to handle the torque and breaking.
This broke the Dual Mass flywheel, which broke the internals of the gearbox.
I replaced the gearbox… but was out of luck as it was broken from start… and some metal shavings got into my mechatronics… I replaced it again, this time it was good but needed to refurbish mecatronics, and still get 2nd and R error. Turned it it was the clutches that are slipping. In the refurbished gearbox they put some aftermarket, cheaper clutches, fine for stock, not fine for supercharged…
Now replacing clutches and hopefully story ends
I’ve done a lot of research and seems the most viable options for clutches are:
OEM = around 1.2k EURO, supposed to handle max 800nm if you upgrade the TCU soft and increase the pressure.
Deca stage 2 = same price as OEM, supposed to handle 850nm stock, up to 1000nm with upgraded TCU software.
TVS has a race clutch, but it’s overkill, it’s 4k EURO and handles up to 1200nm. I’ve spoken to them on the phone, they don’t recommend using it for applications under at least 800-900 nm.
So, unless any of you had any other experience i think the best choice is to go with Deca stage 2, little better than OEM for same price.
Meanwhile, i have upgraded the clutch plate to one from an S7 which was a straight fit and the dual mass i replaced with JHM single mass flywheel (about 4kg lighter than dual mass). I balanced them together prior to putting them on.
I’ve spoken to TVS, it really seems they’re the expert in these transmissions… and i have a dealer of theirs locally (2hrs from me), i think after i install the new clutch, i’ll get their stage 2+ or 3 tune.
Any thoughts or suggestions welcome, or maybe this helps someone in future
