The ecutool.com vagcom cable replicas work quite well (fully featured hacked VAG COM software capable of data logging, adaptation modules…everything), but there are a few things to know:
- the cables don’t change. The software does, so if you have an old cable from them from 2 years ago (say 812.4 or a 9.08), you don’t need another cable to ‘upgrade’…you just need to update the ecutool.com software (link below)
- you need to run a 32 bit version of windows, not 64 bit
- 10.6 is the best version of the software they have. Their 11.1 is still really buggy. The 11.80 was even worse, so they took it down. To make 10.6 work, you need to change your computer’s date to Jan 1, 2011 when you run it. Only when you run it though, not for download/install etc. It’s no big deal as you probably use the cable once a month at most.
- you can download all of the software bundles here in this package:
http://www.sinodownloads.com/down/download/ecutool/3504028VAG118.rar
Again though…use 10.6. It’s the best, most fully featured version, and has no bugs. Just the slight PITA of the date change thing.
I have used an 812.4 cable for ages, and recently bought a new cable so it would be able to log data for B8 S4 (friend’s car). My old cable wouldn’t do it…or so I thought. You can just download the newer SOFTWARE…without needing a new cable. So, I traded my old cable to Axel for a NAV disc.
