Korgdog, I was able to get the water pump off with a little muscle work. Thanks for the suggestion!
I feel bad for whomever gets to remove the front coolant pipe (hopefully never needs…or during a full, non-emergency rebuild :D)
best way to replace the water pump gasket - if you don’t buy it as an assembly - is to use a flathead screwdriver to help guide the new o-ring around the contours of the pump body.
FINALLY some real progress. now to get that damn oil pan on and not leaking…
