update: PPI completed, still working to get the compression test done on seller’s end. results are below:
-right front inner CV boot torn
-both front CV shafts have play, possible cause for vibration at 65-70 and under acceleration
-rear driveshaft carrier bearing not torn but has movement, possible cause for vibration under acceleration
-large oil leak - degrease & monitor to determine location
-A/C inoperative
-weak battery
engine codes:
P1497 - SAI insufficient flow bank 3
P1498 - bank 4
P0491 - bank 1
P0492 - bank 2
01219 - rear side airbag ignitor on drivers side - n201 - upper limit exceeded
01316 - brake control module no signal/communication
also this vehicle has a takata airbag (from reading the various VW/NHSTA releases, seems most/all S6s do)
thoughts? my concerns are the oil leak, brake module, and takata airbag.
replacing CV boots/joints isn’t bad, airbag sensor probably just needs to be cleaned, and I wonder if the SAI was blocked off. admittedly haven’t looked into how hard replacing an AC compressor is…can’t be that bad, right? ;D
