The next stop was a BIG one…Carbon Ceramic Brakes.
I had followed JamesRS5’s journey of fitting factory RS5 front brakes to his Sepang car in Dubai and asked him a million questions. He was very helpful and I started hunting for a set that would be somewhere between used and usable to help get the cost down. I found a set eventually and had them shipped up to me from California. I couldn’t believe the size of them! The calipers were 6-pot Brembos instead of the 8-pot Brembos I was removing. Common sense would dictate that they should be smaller…They were the size of Kleenex boxes!
The rotors arrived separate and were massive to match the calipers. Standard box cutter for size reference.
When held up next to the stock scalloped steel rotors there was a huge difference in weights. The carbon rotors weighed 11lbs less per rotor or exactly half the weight of the steel at 22lbs each.
I had the red calipers option on my car and I wanted to keep that look so I sent the calipers out to Kelly Moss Racing in Madison, Wi and had them powder coat and rebuild them. They did an amazing job and it’s one hell of a facility. This is what I received back:
The dealership that built my car installed the new CCB package for me. I was under warranty and felt it was the best option at the time. They coded them in for the “disk brake wipe” and away I went. Next day I found that they had let brake fluid drip down the face of the brand new caliper…it sat overnight like that and I had a pink drip line top to bottom on the driver side face of the caliper. Not good! Nothing came of it though as after heat cycling a time or two it magically went away and turned back to red again. All is well…
“So how do they drive?” It was the most immediate seat-of-the-pants mod yet. Everything felt better: The acceleration was faster, the suspension feedback was more defined, steering seemed easier, THERE WAS NO MORE BRAKE DUST, they don’t rust up after a wash and best of all…they stop you properly. There is a little more travel in the brake pedal with the CCB over the steels I noticed. It is a less jerky ride now and they don’t seem as touchy on first grab. Some might call that less resposive.
Next up: Euro Exclusive Interior
