Thanks for everything, Todd! Your shop is awesome and you guys make real quality stuff!
added
Interesting to see your MPH at the 1/8th was excellent on the second pass. Makes it tough to pick up much more on the second half, but you only picked up 21. Any trouble?
My 3rd to 4th wasn’t as great as my first pass but it was still pretty stellar.
well you’re the fastest 6sp and the 2nd fastest pump time…and you are now faster than the fastest RS4 all motor (Scheiss!)
Hopefully NY07RS4 gets out there with Tsivas and yourself here soon while the weather is great for power.
Time to get to TMP soon. Does anyone know the published weights of the Alufelgen SF71 in 19x9.5? According to tirerack my PSS’s are 27 lbs and I think my wheels are 23-25. With 8-10 lbs less per corner than Pete, 11s could be there on pump with that setup and closer to 1/4 tank of gas than what he ran. I also need to see the weight difference between the stock front brakes and the Brembo BBK I have to see how much additional rotational weight savings may be their.
19x9.5 ET22 weight: 27.0lbs
Yours likely weigh a bit less with less offset material (nominal difference(+)
Those look awesome.
Where did you get that weight figure from? I have seen a couple different numbers mentioned. I haven’t put them on the car yet so I really should just weight one wheel with tire to be certain.
modbargains. They weigh their wheels that they sell on a digital scale.
http://www.modbargains.com/images/Products/Sportline/Comparison/CSL-wheel-comparison-weights.jpg
Thanks. I saw this picture and assumed that these were the correct size.
http://www.flickr.com/photos/alufelgen/7515031418/in/set-72157630450601298/
Really excited to see what Paul will run in the RS4. I have a feeling we might be both making some 11 second passes on pump ;D
Here’s the thread from Audizine on Austin’s run.
Yes weigh the wheels first. I have seen variances between the spec weight and the actual weight once measured.
I found this old thread, I got about 2lb/corner less with the 380mm Brembos, which seems about right in line with Primetime’s weights.
http://audirevolution.net/forum/index.php?topic=705.msg14835#msg14835
Salmon, Bear, I’d likely be good to go (edit NEXT) weekend one day, but likely in another car, depending on the weather. Maybe gunning for 10s lol.
sakimano:
Hard to say…the stars will REALLY need to align for him. Don’t forget he’s doing it without a supercharger spinning at 20,000 RPM!
Yesterday would have been a great chance. He’s still working on clutch break in apparently.
DSG is like fucking voodoo!
11.89-11.90-11.90-11.92-11.95
That’s pretty solid for catted
Someone remind Austin that on Arin’s list, rynurz is faster with cats.
Yeah, I have had a few days like that… bracket race cars for sure… I let him know on QW, fuck vendorzine!
salmon:
I will weigh them when I get home and report back. So I may be 6ish per corner lighter wheels and another 2 from the brakes.
I think I know what you will be running to get in the 10’s and I must see that!
EDIT: 52.2 lbs for an Alufelgens SF-71 with Michelin PSS 275/30-19.
[quote=“salmon,post:418,topic:4073”]
Just for reference my stockers with Dunlop Sport Maxx GT were 58lbs per wheel… My BBS CHR’s with Conti DW’s are 47lbs per wheel… I am thinking about some OZ Superforgiata for my TT-RS once it arrives… They are like 18lbs a piece… Kind of pricey but I think they will look good as well on the RS in gray/gunmetal…
Also, has anyone measured the pulley yet? I want to see if it is truly smaller than the APR one… Sorry, if I missed it but hadn’t seen an actual # yet…
Love the Superforgiatas. Things weigh 17.4lbs in 19"… Crazy.
