Yeah, amazing. I have to admit, I probably let the sounds of the Audi v10 exhaust clips on youtube sway me into buying the car. It is friggin intoxicating with an aftermarket exhaust.
So, I should have the car in a couple weeks, and then I have to have Eurotech do the safety and emissions. Then, the plan is to get it down to CV so he can run a compression test and check everything over. Once it is given a clean bill of health then we can look at next steps.
Once I have some significant progress, Ill post a build thread in the C6 section. After 10 years, it looks like I have finally graduated from grade 5! C5 that is
Its a cool car. Comfy, big enough, rare as hell, and with susoension addressed, the biggest weakness will be addressed. Wirh tune and exhaust the second biggest weakness will be addressed.
Max Speed:
52000 RPM
Max Boost:
22 PSI
Max Flow:
1150 CFM
Max Power:
775 HP
Peak Efficiency:
78%
Yes, that would be awesome. A supercharger was something I was wondering about. A couple questions…
The ZF 6HP26a is rated to 440lb/ft. I am assuming it can take more, but how much more? Guys are dynoing about 350awhp/350awtq with an exhaust and tune, so it is already close to the max at that level. With the supercharger, would you cap the tq at around 500, and see the bigger gains in HP?
Right now, the car is very jerky in first, stock without a carbon clean. It has a 3.80 final drive with a 4.17 first gear. If I added a supercharger, is it going to make this car unsafe in winter with snow tires? Or maybe the answer is a detuned flash for winter driving
I have been doing some reading on the v8 and v10 Audi FSI engines. Seems that the v10 in the S6 is like the big brother to the v8 4.2 FSI found in the Q7. It has the more restrictive exhaust with ceramic cats, and shares the same forged rods of the Q7 4.2. It is also designed for a redline about 7000rpm.
The Lambo V10 560-4 is like the big brother of the RS4 4.2 FSI. The V8 has a balanced crankshaft and other items designed for the 8250rpm redline. Cams are designed to work well with the higher redline.
If you look at the dynos, the Q7/S6/S8 engines do very well lower in the powerband, where the RS4/Lambo and R8 engines blow them away up top.
Anyway, this was interesting to me because it shows that improvements definitely could be made in the exhaust portion of the S6 v10. Also, MTM does a supercharger for the Q7 4.2 that takes it from 350hp to 500hp. If you run something with similar boost on the S6, you are looking at somewhere around 600-650hp.
Also, there is a modified version of the 6HP26a used in the RS6 that can take a TON of power. However, used RS6 transmissions are $10k and only found in Europe. I was looking for a rebuild kit to see if mine could be rebuilt with the RS6 parts. Havent found any yet. Would have to talk to the guys overseas.
LevelTen - they do rebuilds but I have heard mixed reviews. What is the opinion around here of them? Could they rebuild this trans to take RS6 levels of power?
I was advised that the level10 stuff wasn’t worth it, doesn’t actually strengthen the transmission. Maybe it’s possible to use parts from the rs6 transmission…
Are there similarities between the lambo v10 and yours? Could probably get a ridiculous amount of power with the v-3 si.
There is a guide that compares the Q7 4.2 FSI to the RS4 4.2. The S6/S8 v10 are more like the Q7 engine with two extra cylinders. The RS4 4.2 is more like the R8/Lambo 560-4 engines, from what I can tell.
I can’t find the study guide for the R8 or Lambo v10, but it looks to be a lot like the RS4 engine, and there is mention of it in the 4.2 and 5.2 study guides.
I would guess the engine and trans would safely make about 650hp crank with a supercharger. 500tq at 7000rpm is 666hp (that would be a nice peak number for a mean sounding blacked out S666). I am sure you could make more, but maybe the rods and transmission would be of concern.
Actually, I am no expert, but I can’t see the forged rods being unable to handle at least 75lb/ft each. So, they probably wouldnt be of a concern. Just the transmission then. Ill have to investigate the RS6 rebuild kit some more.
The connecting rods are a familiar trapezoidal design
forged from 36MnVS4 high-strength steel. This
design reduces oscillating masses and distributes the
combustion force more evenly.
The lower end of the connecting rods are cracked after
forging. During the cracking process, the connecting rod
is split at a predetermined breaking point using a special
tool. The resultant unique breaking surface ensures the
high joining precision of the two mating parts.
The connecting rods are cross-drilled to allow engine oil
to lubricate the rod bearings and piston pins.
Pistons
The cast aluminum pistons are manufactured by the firm
Kolben Schmidt. They have a special piston head design
that supports the FSI combustion principle. The design
aids in the tumble effect of the fuel mixture during its
intake stroke.
The piston skirts are electro-coated with a special ironbased
friction reducing material to minimize wear under
load.
Spray jets located on the engine block provide cooling to
the underside of the piston and the piston pins.
I make well past what the 6hp19 should make. My peak Tq is much more then what the transmission says it should be able to handle. The differences between the transmissions you have and the more power ones. Are the clutches and the pump. I know CV can tune that transmission because he tuned mine and it dosn’t slip and shifts faster.
Also look at the B8 S4 guys. They are making well past what there transmission say they can make.
Motor wise I don’t know much. I hear a few motors have issues with head stuff. And some with chain issues. I was in a local S8 CV tuned and exhaust car they are crazy.
A little more info from another v10 study guide I found.
I was thinking the engine was just a v8 FSI plus two extra cylinders. It is, but there are a few other things different. From the guide:
Basic engine
The V10 FSI engine is based on the V8 FSI engine,
which has, in principle, “only” been upgraded to
include an additional pair of cylinders.
The basic concept of the cylinder crankcase and the
cylinder heads, as well as the timing gear, the fuel
system and the intake manifold concept, have been
adopted unchanged.
On the other hand, the crankshaft with balancer
shaft, the double-chambered intake with dual
throttle valves, the exhaust manifold and the
ECU concept are features specific to the V10.
