Had to look that up, as I didnt know what it was.
Vortech V-3 Si Supercharger
Performance Specs
Max Speed:
52000 RPM
Max Boost:
22 PSI
Max Flow:
1150 CFM
Max Power:
775 HP
Peak Efficiency:
78%
Yes, that would be awesome. A supercharger was something I was wondering about. A couple questions…
- The ZF 6HP26a is rated to 440lb/ft. I am assuming it can take more, but how much more? Guys are dynoing about 350awhp/350awtq with an exhaust and tune, so it is already close to the max at that level. With the supercharger, would you cap the tq at around 500, and see the bigger gains in HP?
- Right now, the car is very jerky in first, stock without a carbon clean. It has a 3.80 final drive with a 4.17 first gear. If I added a supercharger, is it going to make this car unsafe in winter with snow tires? Or maybe the answer is a detuned flash for winter driving
I have been doing some reading on the v8 and v10 Audi FSI engines. Seems that the v10 in the S6 is like the big brother to the v8 4.2 FSI found in the Q7. It has the more restrictive exhaust with ceramic cats, and shares the same forged rods of the Q7 4.2. It is also designed for a redline about 7000rpm.
The Lambo V10 560-4 is like the big brother of the RS4 4.2 FSI. The V8 has a balanced crankshaft and other items designed for the 8250rpm redline. Cams are designed to work well with the higher redline.
If you look at the dynos, the Q7/S6/S8 engines do very well lower in the powerband, where the RS4/Lambo and R8 engines blow them away up top.
Anyway, this was interesting to me because it shows that improvements definitely could be made in the exhaust portion of the S6 v10. Also, MTM does a supercharger for the Q7 4.2 that takes it from 350hp to 500hp. If you run something with similar boost on the S6, you are looking at somewhere around 600-650hp.
