Hey guys, I was advised to start a thread here to see if anyone can help me get some timing issues I’m having with my car sorted out. This is going to be a long post but here it goes:
In December I pulled my motor to install a set of JHM headers, ported intake manifold, the updated JHM tune with the header file, and a Clutch Masters FX400 with their billet flywheel along with a few other things.
Here’s all of the engine/performance mods I have on my car:
JHM Headers
Ported intake manifold/throttle body
Intake spacers
JHM tune
CM FX 400 w/ lwfw
FI res catback
JHM Pulley
I basically have a full bolt on car.
The Problem:
My car’s pulling so much timing its running in a soft limp mode. Basically from low rpm’s up until ~5k it’s a dog. After 5k the car pulls strong with no hesitation or feeling that it’s being “held back.” I’ve sent several rounds of logs back and forth to JHM and we’ve found that it’s a mechanical/electrical problem. The car is pulling so much timing that when starting the pulls in 3rd gear it knocks like crazy at low rpm. I did a complete scan of the car with vag com last night and this is the only code I’m getting:
1 Fault Found:
16711 - Knock Sensor 1 (G61): Signal too Low P0327 - 002 - Lower Limit Exceeded
I’ve been going back and forth with JHM’s tech support to try and figure out whats the issue and so far we have couple theories:
One is that the tone ring on the flywheel is out of balance and causing the car to run like crap. But, I’m almost positive that this is not the case for several reasons. I haven’t had any weird vibrations through the rev band or clutch chatter, etc. The clutch engages great—it feels like stock. I think if it were the flywheel then all or at least more than one knock sensor would be throwing codes. But it’s literally this same one that keeps throwing codes every time. I haven’t had a single code thrown for anything else so far.
The other problem could be that the knock sensor itself, which I’ll be replacing soon. But from what I understand the sensors generally don’t go “bad.”
Does anyone have any advice as to what else could be the culprit? Or what else I can look into?
I just purchased a vag com so to be honest I don’t really know how to use it to its full potential quite yet. I’m not really sure what blocks measure what, but I do know how to take logs. I still haven’t really figured out how to display/organize the data in excel neatly. Because I don’t really know how to interpret it all that well just yet I don’t want to skew any of the data. If anyone knows of a good resource that’ll walk me through some of the functions it would be greatly appreciated.
Again sorry for the long post, just want to tell the complete story.
