Hi All,
A little about me…My name is Per and I own the RS4 with the AMD S/C base kit, a.k.a. the ‘Stage .9’ setup. Car is a 2008 Avus, Ti, with Sliver Nappa (white) interior. Easy to recognize by the rwerks smoked LED’s, and the fully powdercoated S/C. I’m an end customer with zero affiliation with any tuning company.
http://www.perfarnyphotography.com/RS4/First-Detail/i-CQBpJmG/1/XL/IMG_1575-2-M.jpg
http://www.perfarnyphotography.com/RS4/LED-Tail-Lights/i-PBsVpCB/0/XL/3H4A2986-M.jpg
http://www.perfarnyphotography.com/RS4/AMD-Super-Charger/i-dqxjTpj/2/XL/3H4A3545-M.jpg
Why am I posting? Well, first to introduce myself, but also because I thought that posting some info as an owner of the AMD kit could give a bit of insight and perhaps answer a few questions that I’ve seen posted. Note, I’m not disclosing any dyno or ¼ mile times at this time (I will in the future). In general, I like being a part of the broad Audi community and sharing what I’ve done with my car (http://rs4.thefarnys.com, posting usually just on QW).
Why did I pick AMD for my S/C? When I bought my car, I knew I was going to S/C eventually and found out fairly quickly that APR was really the only viable option available to me at the time (1.5 years ago). Then, as now, the published price was ~$15k, plus install, which I put in my head as “I need $18k for my S/C”, which was too much for me to put out all at one time. Putting the thought aside for a while, I then heard about the AMD development plans around offering stages that should offer similar power on entry for lower price, and higher power with additional investment. That really appealed to me and with my other criteria being local support, and being 30 minutes away from AMD (I live in Seattle), I started discussions with Jason. Based on a lot of conversations with him and having privy to / a ride in the development car (the current 1.0 beta, “fireball”, Avus non-Ti, seen-at-the-strip-car car) I knew AMD was the right product/company for me.
Having perused this site for a bit, I’m compelled to let others know my personal experience with Jason, just so people have one more data point. I’ve worked with him over the last 6 months and have found that on the minus side he can be hard to get a hold of (stopping by works always), and that locking down scheduling for work to be done has been a challenge here or there (reflecting, I believe this has mainly been due to R&D timelines/partner dependencies. Say what you will - I understand development time and how that goes, so I’m OK with how things have transpired). On the plus side: he has pulled through on every single promise ever made, and he has gone above and beyond for me several times. I see he is a perfectionist and I know he will always go to the nth degree to make sure the car is perfect / things are right. I value that highly. Again - so many posts on here talking about some of these characteristics or lack thereof, I just wanted to relay, FWIW, what I have personally experienced.
Where is my car in terms of completion? I’ve been told my car is the first one that has 100% all production run parts on it, i.e. no one-off non-mass produced parts down to the last tiny bracket, etc. I also know that you can purchase the base kit today, and that BBI in CA sold one many months ago. That said, having had my S/C installed a couple of weeks ago, Jason has been further fine-tuning my setup, which I believe will be incorporated into future sales of the base kit. To that end, what can you change on an S/C easily to influence power? Pulley size. That’s the last thing that has been tweaked to determine the right amount of power with the right cooling at this stage. I know that my car has now landed on its final pulley size, and that there is potentially one final software update. Based on my schedule, it’s looking like that should all be set and done the week of April 8th.
Performance documentation that I’ll be sharing when ready: final AMD dyno results, final dynojet results, and weather permitting: ¼ mile time. My philosophy on dyno results: it is a method to baseline your car and to measure improvements. It’s not the only way. I personally believe comparing numbers across dyno’s is an exercise in futility. That said: why the dynojet? Well, I see that assertions in the past have been that the AMD dyno is cooked in their favor, so the thought is to prove/disprove that hypothesis by going to an independent dyno to see how results compare to make sure it’s objective. This is where you can say I’m taking a step beyond just normal customer by agreeing to the time to do both, and I do that not only because I respect Jason/AMD and like backing local business, but also because my car got 282/232 whp/tq corrected on his dyno when stock so I have strong beliefs that it is far from cooked, and actually one of the most conservative out there today. (Endless thread on QW about ‘what’s wrong with your car?!?’ which I don’t really care about as Jason confirmed it’s within normal range of results on his dyno. Again, all up, I just want a baseline and then measure improvement).
http://www.perfarnyphotography.com/RS4/AMD-Super-Charger/i-kchBDgh/0/M/3H4A3565-M.jpg
I saw comments about this pic…I took the picture of the dynojet setup above. Why? Because I thought it’s a bit comical to offer that as your only air movement solution, and I believe you can do better to simulate a moving car at that speed. That picture means that my car was already there, yes. But based on fine tuning that’s imminently finalized, as referenced above, the car will go back again to get final numbers.
Speaking of final numbers: yes, I’ve seen both cars on the dyno (mine and the Stage 1.0), and I know with a relative degree of certainty where they will finally land. What’s causing a lot of angst it seems, yet what I believe is the right approach, is the stance to only share final numbers. Like I said, there are some tweaks still in both kits: very minimal in the .9, a bit more in the 1.0 as I understand it. If it were me, I’d take the same approach, and while I easily could post up results I’ve seen to date, I don’t believe that would do anyone any favors.
Am I happy with what I paid for? Absolutely, 100%. Even my ‘baby kit’ transforms the car completely. I paid $9,999 for the hardware, $749 for the software, so call it $10,750 install included @ AMD (install elsewhere is likely 12-14 hours). I believe (don’t think this is 100% solidified) that the main 1.0 kit will sell for $13,999 software included when ready.
Anyway, I think that’s all I have right now
Sorry this is so long, but I wanted to introduce myself, and thought it might be helpful to share my experience to date with my S/C. Maybe it helps answer some questions, I sincerely hope it doesn’t cause more confusion. If you have any questions on the above, I’m happy to clarify.
Cheers,
Per
