Hidden Horsepower; Stock Intake + Silencer
The jhm tune is cool like that… it seems to be constantly monitoring things…when you make changes to the csr you can almost fesl it adapt…for a free mod the air box gives what looks like a good amount of gusto. .
Quattrodude welcom man…depends on what yoyr talking about. There are three things that are connected to the air box that dont take the air to the throttle body.
You have the air dam on top of the air box coming from the front…then there is the secondairy air lead that is at the bottom and then the scilencdr and air restricfion that you removed
thanks for the welcome! I’m speaking about the one on the front of the box with the smaller hose, not fender side and not silencer.
That is the secondary air pump pick up…nothing crazy most guys remove it
ok so ill just remove it then! excellent
thanks
The Silencer’ little black box’ what did you do just remove it and blank it off
yup, just took it out and blocked off port on tube!
cheers
