It’s a braided hose that is a press fit (by hand) into the rubber intake boot. It does have a connector that looks kinda like a 4-leaf clover (for lack of a good term). I just pull the whole thing out of the boot.
Found a pic:
http://gallery.034motorsport.com/var/albums/Misc/Quattroworld-Media/RS4_Carbon_Clean_4_Small.jpg?m=1326497530
Look to the upper left of the pic and you’ll see the connector for it, and where it feeds down into the valley.
[quote=“komseh,post:42,topic:7650”]
As long as the check valve is the first thing after the vac nipple on the IM, and it’s in proper orientation (holding vac to the systems behind it) then you can rule that out…unless it’s clogged, but I haven’t seen that before. Run the airbox flap test via vagcom and you’ll prove out that part quickly (if you haven’t already). If the vac reservoir has enough to actuate the airbox flap a few times, then that part of the system should be fine.
FYI, The nipple at the bottom of the IM extends ~1/2" into the IM, so that any loose oil that pools at the bottom of the IM won’t get sucked into that vac line.
