I've given up re my sticking clutch pedal
JHM already gave me a pressure plate so when I do get around to swapping them, I’ll send them the old one for inspection.
Castrol SRF runs about $75 a bottle in the US, but you can find it online for a bit cheaper (lets say around $60 if you look). You need 2 bottles for a full flush. So, much more expensive than Motul or SuperBlue but the wet boiling point is simply unmatcheable.
When it comes to dry boiling point, all high perf brake fluids are relatively close. It is the wet boiling point that really sets SRF apart and allows it to last much longer (and perhaps be less susceptible to this clutch problem, which I also have at times).
I have used ATE fluid in the past as it is sufficient for my track needs. But, I might try the SRF next spring/summer as I’ll need to at least bleed (might as well flush then) before tracking again.
Hi everybody! First post, registered specially to answer your question. Found it when I was looking for pedal adjustment; my clutch is a Sachs.
When I had the original clutch I had the same problem. There is an upgraded vacuum line that solves 90% of the problem. It was really a pain and very worrying, not to mention frustrating, seeing that pedal stick to the floor…
Order a clutch vacuum line and make sure it comes new and it’s not sitting at the dealership’s stock, so it’s surely the new version. It’s a quick job, so don’t let anyone stiff you for that.
Well, quick intro, I’m Alex, from Brazil, living near Turin in Italy. Got a 2007 RS4 Avant, Milltek exhaust (less cats, non resonated) and recently had a Revo remap. It’s my dream car and my daily driver. Back in Brazil me and some friends, including Bruno Senna, founded the Audi S Club, for S/RS/TT owners, almost 10 years ago… I’m also building a prototype road car with the A8’s V8 and a Porsche GT3 transmission. :slight_smile:
Cheers!
Alex,
thanks for the tip. I will be interested to see if anyone has given that a shot.
That prototype race car sounds mental!
p.s. pics of your avant?
Hi Alex,
Thanks for chiming in. However, according to my mechanic, there is no vacuum line in the clutch hydraulics.
There is a pressure hose between the clutch master cylinder and the clutch slave cylinder which has been replaced with a SS braided line.
There’s also a feed from the brake master cylinder to the clutch master cylinder but if that feed had issues, I wouldn’t even be able to drive the car.
Alex has an RS4 Avant. Different.
Different what? Different boot space maybe. Same clutch/flywheel/slave/lines etc.
Iirc, the RS4 has a vacuum booster line.
The RS4 AVANT does? But not the sedan? That is strange.
From Alex
"my clutch is a Sachs.
Order a clutch vacuum line and make sure it comes new and it’s not sitting at the dealership’s stock, so it’s surely the new version. It’s a quick job, so don’t let anyone stiff you for that."
I think it applies to all RS4’s, not just the Avant.
I’ve been wrong before, but, as I said iirc.
Guarantee he is talking about the line folks replace. I think he is confusing vacuum line here. Actually sounds like a tech or someone else told him what was wrong with his car and perhaps he misinterpreted.
If it is the lines then I guess it’s not the core issue. I’ve had my sticky clutch both before (while completely stock) and after upgrading my lines to stainless steel and getting the metal slave cylinder too. I think Axel is the same.
If it is indeed the pressure plate we’ll find out in the next few weeks I guess…
My thoughts as well. I think he’s talking about the pressure hose between the slave and master cylinders which I’ve replaced with an SS line to no avail. Was one of my first attempts as it was quite cheap relative to the rest of the parts I’ve changed.
Other than tony has anyone else replaced the fork and “that little plastic bit” on the fork? And the input shaft sleeve?
What “little plastic bit” are you referring to?
Not sure exactly but I recall reading about some little plastic bit on the fork that apparently wears out prematurely. I’ll see if I can dig up those posts. I just figured if the tranny will be dropped again might as well refresh those relatively cheap parts as peace of mind.
But at the same time I wonder if its the same part on the s4 and rs4 though, and even if it were, I wonder why then the s4’s with their own pressure plate don’t have the same sticky issue then. I doubt its the cause of the problem, but maybe something related to those parts in conjunction with the pressure plate is causing issues?
It seems like the clutch still grips when the pedal gets stuck, so I wonder if the issue is the pressure plate not releasing or whether its upstream of that (that fork, slave, lines, master, pedal). I think slave lines and master can be rules out since people have replaced them with no luck. I don’t see how it could be the pedal since its rpm dependant.
If it is the pressure plate not coming back up fully though (maybe just enough to give it a bit of grip?) I wonder what could be strong enough that could be preventing it from doing so. Seems like its getting stuck right at the friction point. The sac mechanism maybe? Also noticed the r series pp doesn’t have the sac mechanism anymore…
Anyways just my diarrhea of thoughts there. Should be interesting to see if the r series system solves not only this but all the random oem pp failures (rivets, springs etc).
But the clutch breakin is going to be a pain lol
Here’re the part #s for the fork lever thing and sleeve.
http://www.audizine.com/forum/showthread.php?p=8470046
I love the official technical description of the part. “Piece” lol
I don’t have an RS4, but I pretty much replaced everything in my clutch assembly sans the shaft sleeve (a new one is sitting in my garage). The only thing that solved my issue (albeit temporarily) was resetting the SAC on the PP.
Does the S4 kit use the RS4 input shaft sleeve and/or release bearing?
