As I posted in the other thread:
[quote]Well! I got up to 960 miles before I can’t drive it anymore. I went to shift into third and the clutch just stayed on the floor. I lifted it up with my foot but as soon as I touch it, it just drops to the floor. Probably not a major issue but certainly inconvenient. I haven’t been stuck in the road since I was a kid. AAA is on the way.
AAA was either going to bring me and the car home (it broke down 1/4 mile away) or to the closest shop (4 miles away). That shop is J-Spec Automotive, owned by Jnaut. So I brought the car there and left him with the clutch issue to fix and remaining stuff to install. Since he works with JHM/CountVohn, the car will be completed there. Onward and upward…
BUILD INFORMATION:
The motor was rebuilt and blueprinted with the following parts purchased from 034 Motorsport:
ROD SET, IE V6 154 — 154MM X 21MM FORGED CONNECTING RODS, AUDI V6
ROD BEARING SET — AUDI V6 ROD BEARING SET, COATED
MAIN BEARING SET — COATED MAIN BEARING SET, GLYCO, AUDI V6
HEAD STUDS, 2.7T — HEAD STUD KIT, AUDI 2.7T RWE-1051
HEAD GASKET KIT — CYLINDER HEAD GASKET SET, 2.7T, Q2 REQUIRED – *** INCLUDES MLS HEAD GASKETS ***
PISTON SET, JE V6 — JE FORGED PISTON SET, 2.7T – 82.0MM BORE / – 86.4MM STROKE / – 9.0:1 COMPRESSION RATIO – TOOL-STEEL WRIST PINS
PISTON COATING — JE THERMAL BARRIER CROWN COATING, JE TUFF SKIRT COATING
2 x Motor Mount, Density Line, B5 (Street Density)
2 x Transmission Mount, Density Line, B5 (Street Density)
Stage 3 parts:
- 034 Motorsport Cold Air Intake X34F Fiberglass – MAF Housing: RS4 or 85mm
- 034 Motorsport MAF hose for B5 RS4
- 034 Motorsport Billet Aluminum Diverter Valves (Pair)
- 034 Motorsport MAF Housing, Billet Aluminum for 2.7T Hitachi or Bosch, 85mm ID – MAF Element: Bosch – MAF Housing Adapter: None
- 034 Motorsport Coil Conversion & ICM Delete Kit, 2.7T to 2.0T FSI Coils
- 034 Motorsport Carbon Fiber Y-Pipe B5-RS4 Replica
- JH Motorsport Lightweight Flywheel and Stage 3 Clutch Combo w B7 RS4 Pressure Plate
- JH Motorsport Solid Short Throw Shifter, B5 S4, Early Style – Shifter Height: Normal – OEM Base for Pre 2000
- JH Motorsport RS6-R Turbos
- JH Motorsport Two Piece Lightweight Slotted Rotors
- Techtonics Exhaust – Cat-Back – JHM Stainless Steel True Dual 2.5 inch System – Downpipe Connection: Dual 2.5″
- Evolution Racewerks Side Mount Intercooler Kit w/o shrouds
- Coolant Sensor (Updated Green)
- Bosch 044 Motorsport Drop In Fuel Pump
- APR Bi-Pipes
- Devil’s Own Methanol Injection System with 50/50 water mix
- Bosch EB 630cc 14 fuel injectors
- NGK V-Power spark plugs
- AR Design 3” Downpipes
- AP Racing 6600 Front Big Brake Kit
- New Turbo Inlet Hoses
- New Head Studs and Gaskets
- New Primary Oxygen Sensors
- New Clutch Fan and Fan Blade
- All new Coolant Reservoir Hoses, Reservoir Tank and Cap
- New Dunlop Sport Z1 Tires 225/45R17
Note from Velocity Factor (original installer):
Key notes: Calibration of the ECU for large MAF housing without grids and the fact that the engine has a larger bore and different compression. The bore is .020 and the compression is 9.0 to 1
Other notes:
The intake manifold was glass beaded; new runners were opened up a little and ported.
Re-done Cylinder heads with new Valve Guides, Seals and Lifters.
