Thanks guys.
The wrap, armor, and clamps doesn’t weigh much so maybe a five to ten pounds overall from front to back. It is spread out across the length of the car so I don’t really care.
Funny picture Saki. If the kid had his arm up signaling touchdown then it would match the X-pipe perfectly.
I was planning on check the exhaust temps on your car since it has a FI catback as well. It would be best if I could do before and after the V1 headers install in a few controlled situations.
Right now the car wants to be difficult. It will not crank consistently. If I keep trying then I can get it to crank a few times to prime the engine with oil then when when I put the plugs in it will not crank at all any more. All the usual offenders (fuses, starter, clutch starter interlock switch, ignition switch, battery, ECU relay) have been replaced so I have some hunting to do.
