I did a bunch of tests on why my S4 wouldn’t crank consistently. Removed a lot of components and checked a bunch of things. Then I did some wiring tests with my Fluke multimeter.
Here is the wiring diagram for the ignition switch (D), starter interlock relay (J434), clutch starter interlock switch (F194), and the starter (B). I did a lot of resistance testing to see if there was any wiring issues. Before I loaded the picture used Paint to add in the resistance (ohms) readings that I saw from each point to point. Does anybody see something that stands out right away?
If you said that the Ohms reading of 4.0155 K ohms from pin 5 of the starter interlock relay connector to the starter solenoid connector was funky then you would be right. The ground wiring reading for the clutch switch is not accurate because I couldn’t find the actual ground so I went off the lower A pillar grounds.
Here are some pictures from when I took that resistance reading.
This is the red lead of the multimeter connected into the pin 5 of the starter interlock relay connector.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_0567_zpseqoubkiz.jpg
A blurry picture of the black lead of the multimeter connected to the starter solenoid connector pin.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_0568_zpsglgfuatm.jpg
This is the crazy Ohms reading:
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_0569_zpsjqgyqxnp.jpg
So it is obvious that the harness is damaged somewhere. That means I have three options to fix this:
- Open the harness up to find where it is damaged. This takes a lot of time to do.
- Replace the whole engine wiring harness. I called the dealership to find out that a new harness costs almost $2K, ouch.
- Leave the stock wiring in place and run an overlay wire that cuts out the middle of the wire from the two points.
So I went with option three.
Went out to the store to get some wire in the right gauge and some heat shrinkable butt connectors.
The relay side of the overlay wire just quickly crimped.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_0574_zpsizqnrphm.jpg
The starter solenoid side of the overlay wire again just quickly crimped.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_0575_zpszq1wg4dv.jpg
I just quickly crimped everything in place so that I could double check that I have a good connection. Here is the Ohm reading after getting the overlay wire in place.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_0576_zpspycagigx.jpg
That is fantastic!
Here is the bad news, I broke the electrical connector that goes to the starter solenoid so I have to wait for a new connector to come in. It should be here Thursday morning.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_0577_zpslwmnlcjd.jpg
Just to triple check my work, I finished up the wiring repair and reconnected everything. Then I tried starting the engine with the starter just dangling by the harness. I could hear it whine and I actually took a video of that with my gopro but I have to reinstall the older gopro studio software because my video loses the sound once I get to step two.
