First let me say that JHM has been a wonderful company and always helped me with both the cars i’ve had since the first time i pulled up unannounced years ago. JHM is a great company to always have around which is why I support them as much as I can. I feel lucky that im close to a company that primarily stocks S4 parts ready to go on there shelf, which saves me and others time from waiting long periods of time when your car is down or in need of something simple.
I have personally driven a few B5 S4 cars with your typical Stage 3 B5 RS4 pressure plate, clutch, and flywheel combo. I know the performance, reliability, and drivability has been pleasing to many others in the past and has done its job well… till now.
Before I bought my first B5 S4 recently I had the pleasure of driving Jason’s JHM/Vortech supercharged B6 S4 and his B5 S4 with the new JHM Stage 4 Clutch and Flywheel combo and instantly fell in love with it!
Feel: The pedal is more smooth and doesn’t have that weird clutch pop feel of the stage 3 B5 rs4 clutch plus there is less pedal effort. This clutch and smoother, not hard to push, and releases closer to a stock style clutch. Im still breaking in the clutch and getting used to it but it chatters very very little at rpms around 1000-1100, but could just be me.
Engagement/shifts: I have the 034 Track Density engine and transmission mounts, JHM DTS and all the full JHM shifter upgrade treatment so I can feel every little detail making it easy to pinpoint and diagnose issues if I have them. the disk is a Feramic on the flywheel side and Kevlar on the pressure plate. The shifts are great! Never any weird engage/disengage feel. just great JHM clutch and flywheel combo
Pros:
New technology clutch
better material
metal components instead of plastic (pressure plate
Feramic/Kevlar disk
Holds 18% more clamp load over the stage 3 B5 rs4 pressure plate
Bolt on flywheel that is setup correctly for the OEM B7 RS4 pressure plate
Great price
Cons:
None
Oh BTW, I fell in love after scratching second on a 1-2 power shift @ 18 psi with K04s after making sure it was broken in. Skeet Skeet.
need to do more aimless wandering around the city.
