Had a manual B7 A4 2.0T Quattro in for some work over the past couple days. I took advantage of the beautiful weather and finished everything up today. Happy Thanksgiving!
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1378_zpsxrqizhtr.jpg
This was the first car that I got to try out something on. My father and I rigged up a car cover that went over the lift so that I could work in the rain. The cover has two support bars that go across the bottom of it and those two bars are sitting on the platform of the lift. The two support bars are secured with ratchet straps to the platforms of the lift so that the cover doesn’t move much. The cover goes up and down with the lift and the car that is on the lift. We had to cut holes in the cover for the two front columns of the lift so that they would clear the cover for when it goes up and down. The cover over hangs the front of the lift to about the edge of the concrete so I can work on the front of an Audi in service position and not get wet. There is still enough room on the side of the lift that I can comfortably take wheels and tires off to do brakes, suspension, and other repairs. It is a fantastic modification to the lift that was long overdue!
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1379_zpsen3pleye.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1380_zpszl8vk4qj.jpg
First thing up for this car was a high pressure fuel pump rebuild. I took out the high pressure fuel pump. Then the old internals are out. The new internals are set on top of the baggies to keep them clean. In the install video that JHM has for the high pressure fuel pump rebuild, Jason says that the cap of the new internals when it is crimped down over the piston that it should be like 2 millimeters from the top to the side. Well my micrometer read 2.04 mm so I think that I was right on the money. Then everything was buttoned up so that I could get the high pressure fuel pump reinstalled.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1381_zpsr3cym8n2.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1388_zpsluvkbdr1.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1390_zpsxojbxu1h.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1392_zpsgpmgigyo.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1391_zpsuhezmxvn.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1393_zpsl766cbbt.jpg
Before I reinstalled the rebuilt high pressure fuel pump, I replaced the camshaft follower. The old camshaft follower had a little normal wear but these things are cheap so why not throw in a new one. The new part is on the left and the old one is on the right.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1394_zpsuxstypsv.jpg
Both front inner CV boots were torn and leaking so I replaced the boots and cleaned up the mess. Didn’t take pictures of the new boots because it was dark when I replaced them.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1398_zpsx42rhsrn.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1397_zpsaveqcqzt.jpg
Exhaust wise, this car already has all the goodies. He has the JHM test pipe, JHM Y-pipe, and a stock B6 S4 catback. The only down side was the center exhaust clamps but he had to do it when he originally installed the exhaust. One of the original OEM center exhaust clamp studs snapped off when I tried to loosen the nut and on the other side I had to cut off the sleeve after I took the American C and bar style clamps off. Kind of jumping ahead of things but I replaced those with new OEM clamps, since they were cheaper than the aftermarket clamps, after finishing up the rest of the other stuff. All the exhaust hardware and clamps got a healthy does of anti-seize because I hate rust/corrosion and it snows here on a rare occasion.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1403_zpscikpyttb.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1402_zpskrjlipk5.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1401_zpsbuuwgrkc.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1404_zpstuyulahw.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1439_zpsb2gurzq1.jpg
Pulled the transmission out. It had a noticeable pink portion on the top right/passenger’s side of the bell housing.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1414_zpsetyofnyk.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1415_zpsegj6bpc6.jpg
Once the transmission was out of the way, I took the pressure plate, clutch disc, and dual mass flywheel off. The 2.0Ts are a lot easier to work on than the V engines so I use a serpentine belt tool and a shallow 12 point 19 mm socket to hold the crank in place to loosen the pressure plate and flywheel bolts. It rests against the snub mount bracket. That way I can do this by myself and I don’t need help. The clutch was the main reason why this guy came to me. He had been noticing that the clutch was slipping. I drove the car prior to doing this work. While going WOT in second and third gears the engine rpms would fly up, then go back down, and then the car would actually accelerate. There were noticeable hot spots on the pressure plate and dual mass flywheel. The clutch disc looked glazed too. Also removed the throw-out bearing and it wasn’t too bad actually.
Serpentine belt tool and a shallow 12 point 19 mm socket holding the crankshaft in place:
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1421_zpsvequcyjb.jpg
Overview:
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1410_zpstemwtdgs.jpg
Pressure plate:
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1412_zpsukowcfb5.jpg
Clutch disc pressure plate side:
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1411_zpsrocdyys4.jpg
Clutch disc flywheel side:
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1413_zps2fzdv2uo.jpg
Dual mass flywheel:
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1409_zpsf8zzqhus.jpg
While I had the clutch and flywheel components off, it was a good time to address the leaking rear coolant flange. The owner had noticed that there was a coolant leak from the back of the engine but he wasn’t sure where exactly it was coming from. I looked before starting the repairs on this car and it wasn’t clear exactly where it was leaking because I saw pink coolant residue around the rear coolant flange and the engine coolant temperature sensor. So I told him to get a new rear coolant flange, grey engine coolant temp sensor, sensor o-ring, and sensor C-clip. They are all fairly cheap parts but it is a major PITA to replace from the top. Search 1.8T rear coolant flange for some horror stories from the 1.8Ts that are fairly similar. But the 2.0Ts are worse in my opinion because there is a mechanical vacuum piece on the back of the cylinder head that gets into the way and makes it impossible to see the rear coolant flange. Thus it was the perfect time to replace those parts while the transmission was out. By the way, the 2.0Ts use the grey two pin engine coolant temperature sensor instead of the older green four pin engine coolant temperature sensor like the older cars. The older cars needed the two sensors in one for the ECU and Instrument Cluster but the 2.0T sends the engine coolant temp reading over the CAN bus from the ECU to the instrument Cluster.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1406_zpsg7zm3r80.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1405_zpsrmnp2wmp.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1407_zps01yoombq.jpg
After the coolant leak was addressed it was time to install a new JHM lightweight flywheel and stage 1 clutch kit. I use the same serpentine belt tool and socket to hold the crank in place to tighten the new flywheel and clutch kit. It rests up against old outlet of the front cross pipe for the factory intercoolers. This car has the big AWE intercooler. That means the front cross pipe is just hanging there taking up space so why not make a good tool stop, right. The JHM lightweight flywheel looks soooooo pretty. It really is a shame that it has to be hidden away. I used red locktite on the new OEM flywheel bolts. The flywheel has to be slowly walked down on the crankshaft since it is an interference fit so I went in a star pattern and turned each bolt 90 degrees at a time until the bolts were tightened to the multiple different stepped specs that JHM says in their instructions. The final step was to turn the bolts an additional 90 degrees and while my fancy Snap-On torque wrench does torque angle for stretch bolts, I still like to mark the bolts with white out just to be sure. Then the clutch disc was put into place with the alignment tool. Next the pressure plate was installed. Red locktite was used on the pressure plate bolts just like the flywheel bolts. Again I slowly walked down the pressure plate bolts by turning each bolt 90 degrees at a time in a star pattern just like with the flywheel until they bottomed out and then I torqued the bolts to spec, again in a star pattern. I had to hold the clutch disc alignment tool in position until the pressure plate was starting to be walked down. After the pressure plate was fully tightened the clutch disc alignment tool came right out and went back in really easily so I know that it was aligned correctly.
Side Note: I really don’t understand what is so complicated about doing this. So many shops mess this up and it is incredibly simple. If it is done right the first time then it doesn’t have to be taken apart to fix things later on.
Serpentine belt tool and socket up against the outlet for the front cross pipe:
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1425_zpsj6ecid7q.jpg
Lightweight flywheel on:
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1426_zpsa7apkoel.jpg
Red locktite for the flywheel bolts:
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1423_zpsg3tuoxir.jpg
Close up picture of the flywheel bolts with locktite and whiteout:
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1427_zpswsv9yvfk.jpg
Clutch disc and alignment tool in place:
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1428_zpseoyevaqj.jpg
Pressure plate on:
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1430_zpsrbm0tgnw.jpg
Red locktite on the pressure plate bolts:
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1429_zpseuofhwek.jpg
The JHM stage 1 clutch kit came with a new throw-out bearing. I use Audi grease to lube up the sleeve for the throw-out bearing. That way the new throw-out bearing slides easily on the sleeve while attached to the clutch fork. This is a step that I think that most shops also mess up on. If you just slap the new throw-out bearing on without any lube then it tends to get stuck and that can lead to weird clutch pedal behavior.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1417_zps3my4hdow.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1419_zpsa99oewkb.jpg
Before I put the transmission back in, I pulled the cowl drain pieces out. There are two cowl drain pieces. One is under the battery and the other is under the brake booster. These little pieces get clogged with leaves and debris. Especially if the person parks under a tree where the leaves and debris fall in the cowl area. Then during heavy rain the water can back up into the AC opening and fill the interior with water. I have seen A4s where it looked like a swimming pool that spills out when you open the front door. That usually causes a total loss situation as far as most insurance companies are concerned so I wanted nip that in the bud.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1435_zpsfmpwxgkn.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1434_zpsg8cl05dd.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1432_zpsu84cgumj.jpg
Hope that you guys had a great Thanksgiving!
