Before carbon cleaning cylinder 7:
http://i284.photobucket.com/albums/ll37/Jimmybones777/Preclean%20cylinder%207_zpsro1paaup.jpg
After carbon cleaning cylinder 7:
http://i284.photobucket.com/albums/ll37/Jimmybones777/Postclean%20cylinder%207_zps7k1a1zps.jpg
Before carbon cleaning cylinder 8:
http://i284.photobucket.com/albums/ll37/Jimmybones777/Preclean%20cylinder%208_zps7zzjgkw0.jpg
After carbon cleaning cylinder 8:
http://i284.photobucket.com/albums/ll37/Jimmybones777/Postclean%20cylinder%208_zpszglxsw3y.jpg
Cleaned the intake port dividers.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1194_zpspnnvl2ac.jpg
Also cleaned the lower side intake manifolds and flaps since they were covered in carbon too. I wanted to show how these things work so I give an overview shot with the piece off the car. One picture with them off the car has the flaps open and the other has them closed. To close the flaps vacuum is applied to the mechanism and that pulls the flaps closed. I have a vacuum tester tool set so I pulled vacuum on the piece to show the flaps working correctly. Then there is the pictures of one of the intake ports with the lower intake manifolds reinstalled. You can see how the flaps block off part of the intake port when they are open. Then there is another picture of the individual intake flap to show the difference when the flap is closed.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1195_zpspxie5ehb.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1196_zps3j1txi95.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1198_zpsq3wayyfk.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1199_zpsqdteopy8.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1200_zpshw25npe0.jpg
While we had the front end moved forward it was a good time to replace the old serpentine belt, tensioner, idler roller, and install a JHM lightweight crank pulley. The serpentine belt should be replaced around 75K miles and this car is well past that. The tensioner and roller both are great to replace at the same time to eliminate another possible reason that the front end may have to be moved forward into service position for. The light weight crank pulley shares the same dowel pin hole as the factory heavy crank pulley so that the crank pulley only goes on one way. I had to swap the dowel over from the old heavy stock crank pulley to the newer light weight crank pulley. The front of crankshaft also has the same corresponding dowel pin hole as the crank pulley. The front crank seal had a little oil seepage around it but that is nothing to worry about so I cleaned it off and tightened things up.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1097_zpsiucwdxym.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1103_zpsxfcswelw.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1104_zpsq6bsnetg.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1105_zpsucqnwvek.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1106_zpssfej3iph.jpg
Along with the spark plugs were replaced and the JHM oil separator heater bypass was installed but I can’t find pictures of that at the moment.
Okay so the car leaves and the check engine light comes on. He brings it back to me and I scan it to find fault codes for the side intake manifold flaps stuck open. To diagnose this, I take the intake manifold off and start poking around. All the vacuum lines for the side intake manifold flaps hold vacuum for my tester and the flaps move correctly so I try pulling vacuum on the solenoid valve that controls the side intake manifold flaps and it does not hold vacuum since it is stuck in one position. Also looked at the other vacuum lines and one 90 degree elbow that was unrelated to the side intake manifold flaps was cracked and broken. I replaced the solenoid valve and the bad other vacuum line. Then the flaps seem to be working correctly.
http://i284.photobucket.com/albums/ll37/Jimmybones777/20151027_164249_zpsbkdqzwqv.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/20151027_164145_zps4zjbwmsm.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/20151027_121603_zpsnxlnhfjy.jpg
The car leaves again. He drives up to a wedding in PA and back over the following weekend. Then he goes to start it up over after getting back and the engine will not start. I go over late at night after finishing my events for the day and I bring along my Vagcom cable to see what fault codes are present and what else I can find. I start the engine up and it then dies. Try again and the same thing happens. I try one more time but as soon as it cranks over I give it some gas and then the engine keeps running. We could both hear a really loud whining/whirling noise from under the car, where the right rear seat would be. Kind of like the low pressure side fuel pump is struggling. So I let the engine die and then scan fault codes. The only fault code that shows that a reason why the MIL/check engine light is on is P0087 or low rail fuel pressure. I go into the measuring value blocks and look at a few different things. What eventually stands out to me is on the third measuring value block line down. That is channel 140 and it displays the specified or called for high side fuel pressure and the actual high side fuel pressure. It shows that the high pressure side of the fuel system is running at 6-7 bar of pressure when the engine is requesting between 25 to 30 bar of pressure. That means that the high pressure fuel pumps had failed and the low pressure side fuel pump in the tank was running at 100% of its duty cycle to try to keep the engine running but it couldn’t keep the rail pressure high enough. Normally the low side fuel pump runs around 5-6 bar of pressure with correctly working high pressure fuel pumps.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1221_zpslazl9g4z.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1222_zps5obrggpn.jpg
I ordered two high pressure fuel pumps and when they came in I actually replaced them in the parking lot in front of his place. The high pressure fuel pumps are right on top of the engine and very easy to get to, plus you can see all the way around them. The older and more experienced techs at the dealerships that I worked with in the past would always say that if you can see the part that goes bad clearly and reach all the way around it that it would usually never fail. Well the high pressure fuel pumps are a rare exception to that. It seriously took longer to go to the dealership, go back to my house to grab the tools needed, and then go to his house then the time it took to replace the high pressure fuel pumps. After replacing the high pressure fuel pumps the engine starts and revs correctly. The actual high side rail fuel pressure matches what is being specified/called for.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1226_zpstze4e8iz.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1228_zpsgwuyxtzw.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1227_zpsymnxwivl.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1229_zpsnjqzyh5q.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1233_zpsq8euysok.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1234_zpswx5sw0au.jpg
By the way, I figured that I should mention for the timing belt 2.0T guys out there that the FSI V8s use a camshaft follower with a metal roller so they never have an issue with the camshaft follower for the high pressure fuel pumps.
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1232_zpsnaapqu8c.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1230_zpsbfw4xkus.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/SAM_1231_zpssoatdipc.jpg
