To update this thread I had the Killer Chiller working in dual zone mode until my AC compressor died back in May. Sadly I haven’t had any time to work on my car since then so that is why I haven’t posted much. Currently I have my car tore apart to replace the AC compressor and do some other maintenance so I figured that now would be a good time to update some of the RS4 guys that have been patiently waiting.
For those of you that don’t know what I mean by dual zone mode, I mean that the AC is cooling off both the cabin and the intercooler water. It works fairly well in this situation but I wanted better so I had to work through some issues to get what I wanted.
On a side note, sadly the AC compressors are weak on these timing chain 4.2 liter MPI and 4.2 liter FSI V8s and 5.2 liter FSI V10s. After all my research it appears that all the rear timing chain 4.2 liter V8 engines in the MPI versions (B6/7 S4s, V8 Allroads, and early C6 V8 A6s), FSI versions (RS4, Q7, face-lift D3 A8, 2007+ C6 A6, R8, and B8 S5 coupe), and the 5.2 liter FSI V10s (C6 S6, D3 S8, and R8) use the same shaft driven AC compressor. It would appear from a lot of posts recently that the RS4 guys are seeing more and more AC compressors fail and the R8 owners have been complaining about AC issues for years. The other cars I don’t really ever hear about but it wouldn’t surprise me if it is just a matter of time.
Here is where I mounted the Killer Chiller box. I removed the secondary radiator below the driver’s side/left side headlight and looped the coolant lines so that I could mount the Killer Chiller box there. There just isn’t any room and all my other ideas wouldn’t fit because of a lack of space. By the way, I am using BMW blue coolant in my intercooler system to be able to very quickly identify any leaks so that is why you see blue coolant in the drain.
[url=https://flic.kr/p/YQck1t]
https://farm5.staticflickr.com/4441/37301380991_e67cc47cc9_z.jpg
[/ur]
By using the Killer Chiller in dual zone mode I have gotten the intake air temps to 16 degrees below ambient. The water temps usually run about 9-10 degrees colder than that. I am using a simple temperature gun from Home Depot in this picture to show that the water is at about 49 degrees F.
https://farm5.staticflickr.com/4429/37301382291_1fc14c478f_z.jpg
Here are some cool pictures of the water tank and intercooler cooling off.
[url=https://flic.kr/p/YQcki2]
https://farm5.staticflickr.com/4428/37301381951_ac38d81c75_k.jpg
[/ur]
https://farm5.staticflickr.com/4471/37301381491_a53cf842d5_k.jpg
Finally, I am wrapping up replacing the AC compressor and doing my maintenance so here is a quick picture to hold you guys over until I finish things up.
[url=https://flic.kr/p/YQcjTz]
https://farm5.staticflickr.com/4390/37301380591_cd43d46e31_z.jpg
