Justin has a lot of really good points in this post.
It is a different refrigerant than normal R12 that was used in older cars. The Industrial 12A refrigerant from autorefrigerants.com is an aftermarket replacement refrigerant that is a hydrocarbon based refrigerant. I had to explain this to someone that wouldn’t listen to me and it frustrated me enough that I had to tell them to leave because saying the same thing to a wall gets really old after two or three times.
Anyways, I ordered and tested the Industrial 12A refrigerant and it does NOT help. The in cabin cooling effect was awesome but the intake air temps didn’t get as cold than as with normal R134A. Normally driving around town with max cooling I see IATs 30 degrees F below ambient with R134A but with Industrial 12A I only saw like IATs 24-26 degrees F below ambient. It was worse with the other cooling settings. When in dual zone mode while using Industrial 12A the compressor duty cycle would go down to really low values because the evaporator outlet temps would get close to freezing so the 08-HVAC module would drop the duty cycle to not freeze over the evaporator.
The other week I did more testing and had some really good results. It was like 60-50 degrees F ambient that night. The intercooler brass fittings completely frosted over from the water getting to between 12-17 degrees F.
If anyone can find a gauge unit that reads below freezing (0 degrees C or 32 degrees F) for IATs then please let me know because my current gauge is very inaccurate below freezing.
Thanks for te feedback Jimmy, awesome pic, love the frost ;D ;D. Good to know that it is a functional mod that operates as advertised. Cant wait to get going with mine.
Regarding the temperature gauge, what type is it and how/where did you plummed into the coolant loop? Is it the gauge or the sensor that’s not giving accurate reading?
I have the Zadatech gauge unit. It uses a simple two wire 5V temperature probe that I drilled and tapped a hole into the back side of the intercooler housing for. It is reading intake air temperature after the air is cooled off going past the intercooler. I don’t have a temperature sensor in the intercooler water circuit currently but I could add one later on. Zadatech claims that the gauge only reads from freezing (0 degrees C/32 degrees F) to 150 degrees C/302 degrees F.
@jimmy so which refrigerant are you now using? 134a or 12a? Do you think it would worthwhile changing the thermostat to one with a lower temp seeing as you now only have the 1 main rad? Im just concerned with the increased loads on the engine that 1 rad isnt enough. The majority of owners would only see high ambient temps only in summer whereas i see them all year round.
