well lets all not jump our guns here, after finishing installation i took the car for a boot around the shop, no issues came up, left her running as i locked up the place, this is when i quickly posted saying the car is running great, on the drive from there home i noticed the ping come back but not as bad, again figured it was the tune still adjusting, over the last what 3-5 days i think it is, heres what i have noticed so far, and personally i think it could be 3 things.
brief understanding of the ping, start the car in the morning, usually when i have my morning puff and coffee and let her warm up a bit, I baby the car around until the MFD takes away the 7000rpm limiter, and even then i barely get into her until she’s fully unto temperature, but no pings will take place in this time, car runs great, car will continue to run great until she’s up to operating temperature, mind you i don’t really get into the throttle at all so this could be the main reason why.
When she is fully up to temp and i do decide to let her breathe a little, i find that if i put my foot all the way to the floor i get a brief ping ping ping then the car pulls hard, ill continue to keep my foot into it and rev her out(no audible pinging can be heard), and go to grab next gear, same thing happens ping ping ping, then the car pulls hard, again with the next shift and the one after that, although with that being said its more prevalent in the first 3-4 gears then in 5-6.
Now if i only get into the throttle about 20-25% the car pings like crazy! back out of the throttle, then floor it, again same thing happens, ping ping ping then the car pulls hard. I’ve also found that if i rev her unto 3-3500 rpm, then finally floor it its hit and miss on whether she will ping or not.
I have since reluctantly drove her aggressively, not beat on it, but drove her hard while she was still warming up, it is hit and miss with the ping in that time frame as well, it sometimes happens sometimes doesn’t.
Personally i think its 1 of these 3 things. 1) clogged cats? 2)carbon build up? 3)clogged injector?
i dont think its a clogged cat because she should throw if it was one, but i have heard people say that these can cause issues.
seems like a very probable culprit for the issue, to much carbon build up, restricts air flow and also causes the air be disrupted before flowing into the intake. causing the car to lean out and ping.
my fuel filter when i changed it was brown when i poured the excess fuel out of it, so I’m thinking its probable that i have a clogged/partially clogged injector, which would make sense on why the ping only seems to happen in the first 20-25% of the throttle, when the car would be requesting fuel and is not able to keep up with what requested? although I’m not sure on this.
finally does anyone have any info on what i should log? and what numbers they are? im not that tech savy with the vagcom, my tech is amazing, but wants to see if you guys have any insight before we head out this saturday to do some logging and testing, anything i can log to check the injectors?
This is driving me absolutely crazy! but i want to figure out what is causing this problem! mostly because the car is amazing with the tune, everything about it is just so much better, I’m really hoping this thread can hopefully help anybody else out there, as i do plan to keep updating as i progress through the maintenance and just general maintenance and upkeep for a car of this mileage.
i also do want to state, that i change my oil every 3-5000km’s depending on how i have been driving her, and am anal retentive with my maintenance, I know from how this threads turned out so far, that it may seem that I’m not, but my plan was as soon as the car clicked over 80,xxxkms i would be doing a complete refresh of the car, wasnt planning on leaving anything untouched. ( control arms fr and rr, coil overs, motor mounts, trans mount etc etc ) i just clicked over that point now so i hopefully will have some photos of some goodies to post soon!
I apologize in advance for the massive post! but i work 2 jobs, and work/paint cars on the weekends so i dont have alot of free time. lol
