Seeing my Friend’s Rudy’s update time to say also a couple of things for the car…first HUGE public thank you to Rudi for guidance/advise/chatting and comparison between our cars…ones’ thoughts may as well be the others
Got the full free flow exhaust installed on the car Full 2.75" from dps all the way back to the end. Converted the cat housing into a small free flow muffler, added 2 bigger mufflers towards the back to absorb some sound and installed the factory exhaust flap system to the end free flow mufflers. reason for all this sound absorption is that I put my baby son in the car and I wanted to be able to sleep. With the mufflers on “off” position the car is running almost like stock sound with no resonance at all.
The effect on the car was minimal on power…got +5 at very peak whp, but saw gains up to +18 across 3000-7000 rev range and I earned about 2 kgm/nm of torque in the same rev range. the car revs up way more happily, it lost that back-pressure effect feel but it runs way better and smoother all the way to almost the top. Condition were about 35 C so similar and comparable conditions. key note to say is that the previous time in each WOT attempt the bhp was dropping (we did 4). In this case rock steady same results with all 4 WOT tests.
Car has about 3000 fast driven kms since installation including 2 long trips (about 1500 total). Fuel consumption on motorway with speeds between 160-200 kms/h was around 15.5 lt/100 kms and within the city around 16 lt/100 kmw
it is apparent that the tune was developed with a free flow exhaust in mind and it shows. just by removal of restrictions the afr changed from 10.2 to 11.5…11.8. the tune has improved 100% from the previous run with the old exhaust on leaving a small margin between 7000-8500 where it could be improved.
significant “victims” so far include but not limited to (bhp claimed from owners): RS6 C5 with exhaust/tune (730bhp), 997TT stage 1 (560bhp), tt-rs around (520bhp) and a heavily tuned subaru with a 3071R running meth (-350 kg in weight at least…470 whp) which did 1 car pull on 2nd gear…caught him up on 3rd…overtaken at 4th
so far so good!!! …i am looking fwd to Rudy’s Killer Chiller project for results…he leads…I follow
