The KC System is a great idea, personally I like it and based on my experience and for my use it works well. It is an absolute PITA getting it fitted on the RS4. Well I guess it depends where you mount the unit, but in my case as with my Blower install I wanted to retain the OEM look and keep the hoses as short as possible.
Jimmy has done some great work and testing on the KC system and his results speak for itself.
Anyway, apologies for getting of subjet again on your blower thread I will start a install thread on my KC system and give my input and experiences there.
Finially got all of the last parts just last week. I’ve been waiting forever for the seller to get me everything. There are a few little bits I have to gather myself but over all I’m looking to try and get some time to install this before the rush of the holiday. Next month I’m looking to try and start the install.
way to go Justincredible! S/C is the way to go …you go and install the kit and then send us a pic of the smile on your face!
techie question for the operation of the vortech v3 si that jhm uses…I was browsing the vortech site and they have an impeller calculator…did an approx measurement of my pulleys from beneath the car an the stage 1+ is around 3.8 inch and the crank one around 6.6 inch (both as i said approx measurements).
I run the numbers at the vortech impeller calculator with a shift point at 8000 rpm and it shows that the s/c is operating at around 50000 rpm with 52000 being the max allowable rpm. Surely this cannot be right …right? ii mean yes 500+ whp on stage 1+ setups with only 9 psi (max 26 psi) the unit cannot operate at so high rpm… plus with a stage 2+ build motor you should only need to change 1 pulley to get more power (i think…)
what am i missing here? maybe jhm is using a different s/c internal gear step up ratio?
Thanks I’m pumped about the SC and the fact that its JHM and vortech. Its been a winning combination for me for years. I have had several mustangs with vortechs on them and to be honest I was original hesitant to jump into another supercharged car because I had switched to nitrous back in my mustang days and I was so happy with it and when JHM had there nitrous kit and given how they worked with the original guys who started the NOS corp. I was sold.
But after years of seeing the great results and the fact that CV now has a supercharged B6 S4 stage 1 and I have had a chance to drive it a few times. I’m just sold.
Super excited. IF I car is like his I will be very happy. His car is hauling and its only a stage 1 non intercooled.
I’ll answer the second part of the question in a different post.
The Vortech superchargers love RPM. The faster they spin the better they run. From what I remember from recent conversations the JHM team has a very good working relationship with vortech. They were even at the vortech booth a few years ago and Vortech asked to have JHM place one of their cars at the vortech booth outside of sema if I remember correctly.
The point I was making here is as far as I can remember the JHM units are made to handle about 56000 rpm. And about every 1500 above 48000rpm makes about 40whp so you can see you don’t need a lot more rpm to make a big chunk of power as the wheel is in the sweet spot between 48000 and 54000rpm.
I know JHM has been constantly pulling back power on these cars to keep motors happy while making great usable power.
If I’m not mistaken on the stage 1 cars JHM lets a good portion of the boost bleed off in the cam overlap. This way they can spin the blower faster down low and just blow off boost up top when needed. Again the idea is to find and keep the blower in the sweet spot. the max set rpm from vortech isn’t because the blower can’t make more power or spin faster its because its internial lube only likes to get to a certain heat range.
I was ok up until the cam overlap and lost boost part! …then I kinda of lost it…(sorry not very tech savy ::))
Just thinking ahead stage 2 built motor using the same parts of stage 1+ in order for you to get more power you would need to change the s/c pulley only OR adjust the bleed off valve spring to open the bov at higher set pressure?
how would our 1+ kit make more power supported by a build motor?
The JHM stage 2 is more boost and more power in the tune.
With the cam overlap just look at it like JHM is using the ECU to help pull back power and boost in the tune.
So just a small pulley swap and a tune update maybe with updated HPFP units your making a good chunk more power.
Even if you didn’t change anything but added in a built motor. JHM would be able to tune update you for more power. I would suggest you contact CV when that time comes.
So…I have another question in an attempt to understand how stage 1+ works…just keeping it under this thread to have everything tidy.
our kit has a diverter valve and a blow-off valve. I am a bit troubled about what each is doing…giving it a go at guessing:
diverter valve: releases excess air when you lift off the accelerator so that it doesnt return back in the s/c and damages it. if that is the case where does it release it to? atmosphere?
blow off valve: it releases excess air to the atmosphere above the 9 psi limit to maintain the required s/c pressure
When you let off the throttle, or create an environment of enough vacuum, the diverter(s) (you have more than one )crack open. How far open, depends on the vacuum, this sends a large amount of the charge air back BEFORE the supercharger, to be recycled back though the intake system.
Rather than having a blowoff valve, any additional air flow is bled off by using the valve overlap from the camshaft timing and the physical limitations of how much air can be pushed through the supercharger by the pulley size and gear setup combination inside.
By the way, a blowoff valve can be thought of the same way as a waste gate for a turbocharger since it tries to maintain a certain pressure. Since we don’t have one though, the boost pressure can change by physically changing hardware. For instance on my B6 S4 I saw 6.5 psi of boost while stage 1 but when I installed the intercooler kit without changing the SC pulley size, I saw 5.5 psi of boost. The engine made a little bit more power from the bigger intake to the SC, less restriction to the throttle body after the SC from the bigger openings, and the cooler intake air temperatures from a combination of the intercooler (the KC cooling off the water further compounds this) and less pressure forcing the air into the engine. Then a more refined tune made it even better!
Does this make sense?
EDIT: Wanted to give you some applied theory as an example since it was asked about the V3 specs.
When the 3.0T guys change the pulley ratio for the 1320 supercharger by switching out to a smaller SC pulley and/or bigger crank pulley, they are trying to reach that desired bypass valve pressure quicker than normal. That is until the software is changed to allow the bypass valve to not open until a higher pressure. There is a point of demenishing returns though because the 3.0T guys have pullied (not sure how to spell that) up the supercharger so badly that it is so far out of the designed speeds that it was meant for that a ton more heat is generated. The additional heat starts to outweigh the additional air flow and take its toll on the components. Like how Loe keeps causing the intercooler cores to fail and leak, the weak stock catalytic converters melt and clog up, and eventually the bearings/rotors/internal components of the supercharger will fail but that is of course if the engine itself holds up. Good thing for the 3.0T guys that the long blocks are pretty tough!
really appreciate the technical information provided guys. really thankful for this. I am using an obd Bluetooth dongle which is connected to my mobile phone to which I am running the app “torque - lite”. it has a boost/vacuum dial and I do see every time 0.6 bar / 9 psi when I step on it. Cant recall the exact increase in pressure but I will log it and add it for your reference here.
I’m an anxious RS5 owner waiting patiently for the JHM supercharger. I often “cross shop” other models as there’s relevant information and experience that I can gather. I enjoy reading all of this stuff no matter what chassis we’re talking about. But admittedly, there’s a connection between the RS4 and RS5.
One clarification, it’s not cam overlap, it’s valve overlap. Depending on the intake and exhaust cam timing (duration for each, the degree of crank rotation the valves are open), there’s a certain amount of overlap where the intake AND exhaust valves are open at the same time. In terms of boost modulation, this is important as boost pressure can be bled out via overlap when the exhaust valves are still open. Not the most efficient in terms of energy loss but it is a useful tool for a belt-driven supercharger that doesn’t have a hyper-reactive wastegate and boost controller like a modern turbo system.
Also, the KC system…is there a link or better source of more detailed info? I recently ran into a new Infiniti Q60S that was running a tune and using the a/c system to cool the relatively small heat exchangers. The owner had been letting it idle for two hours straight and the exchangers were ice cold. Given the the summertime temps here in Texas where I live, that’d be a good, good thing to keep everything in order and the engine intact.
The DV valve is not a pressure valve so much as it is a vac valve. The valve is held shut until there is a vac situation and that diverts the air back to the air filter.
