Omg AZ is on a roll I swear:
[QUOTE=teknicalissue](This is not a cheap, fake, crap ebay “Electric Turbo Charger”. This is a system the requires at the very least 4 12volt batteries and one single unit can output as much as 18PSI sub 4K RPM)
Hey guys!
I just purchased a 2008 S6 with the 5.2L V10 and was pretty happy with it’s performance. After doing more reading; I found that the weight of the motor was one of its biggest limitations but the potential of a couple of hundred HP is clearly there. Currently; I’m in the process of building an electric supercharger for another vehicle and thought that if there was enough interest; I’d build one for the Audi (It could be used for the other Audi cars as well). After poking around under the hood; There is more than enough room to stick two of the Electric Turbo chargers in there and because they’re electric; you don’t need to mess with oil lines, coolant lines, or exhaust piping. You should just be able to to Drop, Tune, and Go.
To give you guys a little more data; I’ll be using a 15KW motor that will spin at 115K RPM. The electric motor will be attached to a Mitsubishi 20G compressor wheel and housing.
Anyways, I thought I’d introduce myself and throw the idea out there!
EDIT: I should also mention that the cost of each of the electric superchargers will be below 2k. This will make them much more affordable as current supercharging systems out there.
http://www.audizine.com/forum/showthread.php/654421-Interest-in-electric-supercharger-for-the-S6-5-2L-V10
