Membership,
I am new to the website but could really use some help with our high mileage S6 C6 4F. We purchased the car knowing it was going to need yet another carbon clean, as it had the typical rough idle at cold start, but hopeful a good cleaning would get it back into shape. Within the first couple weeks of driving it the oil leak (or river) started showing up by the pool on the driveway and smoke rolling out from the coating on the exhaust pipes (previous owner likely put a new belly pan on it to hide them). Anyways, we read some of the forums, watched a few youtube videos, and pulled the car into the garage, ready to dig in…
after taking the intake off we found the oil had filled all of the channels on the top of the engine and was running out the front holes and down the front. From reading these forums we knew the oil adapter was likely the issue, so we replaced these O-rings, and carbon cleaned the intakes. We thought about doing the injectors but since the car had so many miles we thought maybe they had been done before…yeah right, keep reading
The car ran better once we had it back together but the oil kept running, and misfires were still there when cold (but better). So, we read some more, and pulled it back into the garage for round 2.
Back in it went, this time with the intent to replace the injectors (since the spark plugs and solenoids looked brand new from when we took them out the first time to fix the valve cover gasket leaks, and turn the engine over). We replaced all the injectors and the 4 VVT solenoid Orings (learned that these were issues, too, after Round1). They were extremely hardened - likely due to all the heat-soaking. As well, we replaced the front main seal while we had the car in front-end service mode (thank you forum!). Anyway, this leads us to today…and the misfires continue to get worse - maybe due to more fuel getting into the cylinders, now?
On a positive note, I do think most of oil leaks are taken care of…but only time will tell. We are now seeing cylinders 1,2,5,6, and 10 showing misfire codes (in VCDS Engine II)…and the car is actually running a lot worse than it ever has. Even though the plugs and coils looked new, I swapped 7&8 and 1&2 to see if the misfire moved…unfortunately, they didn’t.
So, I am to the point of doing a compression check (yes, probably should have done this before spending any time or money on this high mileage car)…lesson learned. Anyway, my son and I have had a good time wrenching on this beast together but would love to drive it instead of only work on it
I was wondering is there anything else we should be checking? We verified the fuel rail pressure is correct, and there are no other codes (that relate to engine performance). I forgot to mention that when we had the intake off during Round1 we actually inspected the flappers (and to our surprise) they were all fully functional, so we didn’t have to do a replacement or flapper delete. I would appreciate any thoughts the membership has on if there is anything beyond the compression check we can still investigate. Here is the output from VCDS (but I am a newbie using this tool, too, so any guidance on what else to check would be much appreciated!
Wednesday,30,August,2023,22:58:00:10909
VCDS – Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
Mileage: 326520km-202890mi Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 11 31 15 16 17 19 36 37 42 46 47
4F 52 53 55 56 61 62 67 6C 72 76 77
VIN: WAUGN74F77N050167 Mileage: 326520km-202890miles
07-Control Head – Status: OK 0000
0F-Digital Radio – Status: OK 0000
15-Airbags – Status: OK 0000
55-Headlight Range – Status: OK 0000
56-Radio – Status: OK 0000
61-Battery Regul. – Status: OK 0000
76-Park Assist – Status: OK 0000
Address 01: Engine Labels:. 07L-910-552-BSM1.clb
Part No SW: 4F1 910 552 A HW: 4F1 907 552
Component: 5.2L V10/4V FSI ª0040
Revision: 59H09— Serial number:
Coding: 01050009190F0160
Shop #: WSC 08213 444 69273
VCID: 221DFBDA08CD58CA39F-8076
VINID: 9D19577871161C77801400461CD7F03136
2 Faults Found:
005495 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 326528 km
Time Indication: 0
Date: 2023.08.30
Time: 22:52:30
Freeze Frame:
RPM: 310 /min
Load: 54.5 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 33.0°C
Absolute Pres.: 980.0 mbar
Voltage: 10.922 V
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 326528 km
Time Indication: 0
Date: 2023.08.30
Time: 22:52:46
Freeze Frame:
RPM: 596 /min
Load: 31.8 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 31.0°C
Voltage: 13.208 V
Readiness: 0110 1101
Part No SW: 4F2 910 156 M HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI USA 0020
Revision: --H01— Serial number: 0092046
Coding: 0000002
Shop #: WSC 02335 785 00200
VCID: 2F3B02EE4B1FE5A2A61-807A
No fault code found.
Address 11: Engine II Labels:. 07L-910-552-BSM2.clb
6 Faults Found:
P0300 - 001 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 326528 km
Time Indication: 0
Date: 2023.08.30
Time: 22:52:44
Freeze Frame:
RPM: 698 /min
Load: 31.4 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 31.0°C
Voltage: 13.081 V
000769 - Cylinder 1
P0301 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 326528 km
Time Indication: 0
Date: 2023.08.30
Time: 22:52:44
Freeze Frame:
RPM: 698 /min
Load: 31.4 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 31.0°C
Voltage: 13.081 V
000770 - Cylinder 2
P0302 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 326528 km
Time Indication: 0
Date: 2023.08.30
Time: 22:52:44
Freeze Frame:
RPM: 698 /min
Load: 31.4 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 31.0°C
Voltage: 13.081 V
000774 - Cylinder 6
P0306 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 326528 km
Time Indication: 0
Date: 2023.08.30
Time: 22:53:06
Freeze Frame:
RPM: 687 /min
Load: 32.1 %
Speed: 0.0 km/h
Temperature: 71.0°C
Temperature: 30.0°C
Voltage: 13.716 V
000773 - Cylinder 5
P0305 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 326528 km
Time Indication: 0
Date: 2023.08.30
Time: 22:53:06
Freeze Frame:
RPM: 687 /min
Load: 32.1 %
Speed: 0.0 km/h
Temperature: 71.0°C
Temperature: 30.0°C
Voltage: 13.716 V
000784 - Cylinder 10
P0310 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 326528 km
Time Indication: 0
Date: 2023.08.30
Time: 22:53:06
Freeze Frame:
RPM: 687 /min
Load: 32.1 %
Speed: 0.0 km/h
Temperature: 71.0°C
Temperature: 30.0°C
Voltage: 12.954 V
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01018896230000
Coding: 4619293
VCID: 2E051FEA4C15ECAAAD7-807A
1 Fault Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 165
Mileage: 200540 km
Time Indication: 0
Date: 2017.11.10
Time: 20:23:48
End----------(Elapsed Time: 01:56, VBatt start/end: 13.6V/13.8V)-----------
