Hello. I have a 2007 S6 C6 with 107k. I am new to the VAG world and I have spent the last year learning and sorting out the many issues it had. I’ve mostly enjoyed the challenge, but there’s one issue I haven’t resolved yet and I’m hoping you can help:
As the title states, I have a misfire only under medium to heavy load. It doesn’t throw a CEL, but it can definitely be felt. The car idles perfectly and is smooth with partial throttle. I have logged the misfires with Vagcom while driving and currently the misfires are in 1,2,3,7 & 9. Cylinder 2 is the worst. The others are very slight. I have replaced all the coil packs and plugs. The plugs looked like they were running pretty lean. I ensured no oil was in plug well with minimal change. I ran 2 tanks of fuel with moly injector cleaner which did make a noticeable improvement. I am also running ethanol free fuel which interestingly helped too. I’ve also done a smoke test on the PCV system and replaced the PCV valve assembly. I did find an old DTC code that may be related and I added it below. At this point I’m thinking the injectors may be dirty, but I’m wondering if there is another vagcom test I could run to confirm this? Does this sound like injectors to you? I’m wondering if there is a sure fire test to confirm before I tear into the injectors?
Thank you very much!
230121_ScanLog.pdf (124.2 KB)
Saturday,19,February,2022,17:29:38:25692
VCDS – Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
VIN: WAUGN94F37N089902 License Plate:
VCDS Release 21.9.0: SRI Reset
Control Module Part Number: 4F0 910 930 C Labels: 4F0-910-xxx-17.lbl
Component:KOMBIINSTR. M73 H18 0120, Coding:2129268
Operation: Please select an operation
Channel Description Unit Current val. New val.
02 Service Reminder Status 1 —
40 Mileage since Service miles x100 101 —
41 Time since Service Days 380 —
42 Min Mileage to Service miles x100 100 —
43 Max Mileage to Service miles x100 100 —
44 Max Time to Service Days 365 —
45 Oil Quality 1 —
47 Soot Quantity km x100 0 —
48 Thermal Load km x100 47 —
49 Min Time to Service Days 365 —
Saturday,19,February,2022,17:33:00:25692
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Control Module Part Number: 4F0 910 273 B HW: 4F0 907 273 A
Component and/or Version: Reifendruck 3 H05 0100
Software Coding: 0062725
Work Shop Code: WSC 02335 785 00200
VCID: 221DE5CF48C9B4DB915-8076
1 Fault Found:
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 115
Reset counter: 167
Mileage: 159020 km
Time Indication: 0
Date: 2019.01.27
Time: 16:08:44
Freeze Frame:
(no units): 30.0
Voltage: 13.80 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Friday,01,July,2022,16:03:03:25692
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
Address 01: Engine (4F1 910 552 A)
16:03:00 Group 001: General
0 /min Engine Speed (G28)
93.0°C Coolant Temperature (G62)
0.0 % Lambda Control Bank 1/2
0.0 % Lambda Control Bank 3/4
Wednesday,16,November,2022,21:13:25:25692
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
Data version: 20221026 DS344.0
Address 11: Engine II (4F1 910 552 A)
21:13:22
-7.0 % Lambda Control Bank 1/2
-10.5 % Lambda Control Bank 3/4
0 Misfire Counter
Enabled Misfire Recognition
0 Misfire Counter Cylinder 1
0 Misfire Counter Cylinder 2
0 Misfire Counter Cylinder 3
0 Misfire Counter Cylinder 4
0 Misfire Counter Cylinder 5
34.80 bar Fuel Rail Pressure (actual)
0.00 bar Fuel Rail Pressure (spec.)
3 Fuel Pressure Control Status
Monday,21,November,2022,12:43:24:25692
12:43:22 Group 031: Lambda Control (Lambda Sensor Voltages)
0.99 Lambda Control Bank 3 (actual)
1.00 Lambda Control Bank 3 (specified)
1.00 Lambda Control Bank 4 (actual)
1.00 Lambda Control Bank 4 (specified)
12:43:22 Group 032: Lambda Control (Mixture Adaptation)
-0.4 % Adaptation (Idle) Bank 3 Sensor 1
-4.7 % Adaptation (Partial) Bank 3 Sensor 1
-0.1 % Adaptation (Idle) Bank 4 Sensor 1
-3.1 % Adaptation (Partial) Bank 4 Sensor 1
Monday,21,November,2022,12:52:28:25692
12:52:20
-2.7 % Lambda Control Bank 1/2
2.3 % Lambda Control Bank 3/4
15.8 % Engine Load
0 Misfire Counter
0.0 % Adaptation (Idle) Bank 4 Sensor 1
-2.7 % Adaptation (Partial) Bank 4 Sensor 1
34.20 bar Fuel Rail Pressure (spec.)
34.99 bar Fuel Rail Pressure (actual)
Saturday,21,January,2023,11:40:28:25692
11:40:24
1 Misfire Counter
1 Misfire Counter Cylinder 2
0 Misfire Counter Cylinder 6
0 Misfire Counter Cylinder 7
0 Misfire Counter Cylinder 8
0 Misfire Counter Cylinder 9
0 Misfire Counter Cylinder 10
Saturday,21,January,2023,14:38:06:25692
Address 01: Engine Labels: 07L-910-552-BSM1.clb
Control Module Part Number: 4F1 910 552 A HW: 4F1 907 552
Component and/or Version: 5.2L V10/4V FSI ª0040
Software Coding: 01050009190F0160
Work Shop Code: WSC 66565 257 00032
VCID: 221DE5CF48C9B4DBDD6-8076
1 Fault Found:
008567 - Bank 1; System Too Lean off Idle
P2177 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 173137 km
Time Indication: 0
Date: 2022.11.10
Time: 14:21:34
Freeze Frame:
RPM: 1674 /min
Load: 37.2 %
Speed: 34.0 km/h
Temperature: 91.0°C
Temperature: 21.0°C
Absolute Pres.: 950.0 mbar
Voltage: 13.843 V
Readiness: 0000 0000
. It’s probably going to take me a few weeks because I’m moving slow and very carefully. I will eventually report back…
