Hi Everyone,
Short intro, from South Africa, been an active reader on AR for a year or two, maybe three, and my 1st name is Rudi.
Now, I know that there have been a few RS4 Stage 1 Supercharger build threads over the past few years on AR but I figured given that mine is a RHD with a few things done differently compared to SAR’s in the UK it make sense to make another RHD built thread.
I started talking to JHM about 2 years back but only pulled the trigger late December 2015 and the package arrived in January 2016. I also included the JHM Oil Cooler line upgrade, the 3R Series lightweight flywheel and clutch and combo, 034 Engine, Torque and Transmission mounts.
To be honest, when all arrived and I started unpacking everything I was to say the least a bit overwhelmed when I realized that I somehow had to fit all those parts to the car. My initial plans were to outsource that to a shop to do the build for me but in the end decided against it and just knew that this was something I had to do myself.
Some history on the car, 2008 Misano Red with around 41k miles on the clock. Prior to the Stage 1 build I replaced all the control arms, Back & front rotors, brake pads and also installed a KW adjustable spring kit which allowed me to retain the DRC system. This was done in December 2014. During 2015 I re-covered the Recaro Buckets and did a few other small things. So basically the next logical step for me was to go the supercharger route as I have made the decision that the car is a keeper.
I also fitted 2.75" DP’s and exhaust and literally drove the car from the shop to my garage, parked it and the next day, March 27, the stripping started. I mainly worked over weekends and the install took me just about 4 months from start to finish. The installation has just been completed and the 1st start was about a week ago. So still have to sort out one or two small things with the AC re-gas one of the outstanding items.
I had the help of a buddy that came over to assist with the things where an extra pair of hands were needed but apart from that the rest was done by myself.
Also a big thank you to the guys at JHM, Jake & Dru which were extremely help-full through-out all of this.
So lets get the ball rolling and I will probably post the build over a few days, apologies in advance if I leave some things out or post things out of order etc. but give me a shout and I will try to fix.
Oh, by the way, the Clutch still needs to be done but I will need a shop to assist with that I just don’t have the facilities to do that at the house.
First things first, the package.
All neatly packed with plenty of protection.
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02095_zpszbhyd4zl.jpg
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02099_zpshpcbkm2w.jpg
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02097_zpsng2ojsk9.jpg
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/Charger%20Contents_zpsbpcm2rso.jpg
Stripping Commenced
Bumper was pulled off lights removed, so far so good no problem. Made a point to Bag & Tag every bolt.nut & screw I removed and that paid of big time when it came to assembly time.
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02117_zpsiiyfamah.jpg
Next was Lock carrier removal and well, fluids were lost, she was bleeding different colors fluids from places I never new existed. :o Lesson learned, next time drain some of the stuff off beforehand and keep some containers handy.
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02121_zpsae2eza9a.jpg
OEM pulley removed and ready for the new JHM lightweight one, what a huge different in weight. The new pulley was so light it didn’t even registered a reading on my scale. ;D
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02134_zpsu5g3yvwl.jpg
Old pulley
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02138_zpswgi9gipm.jpg
New Pulley
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02139_zpsp13mexhw.jpg
And first of the new parts bolted to it’s new home.
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02140_zpsvrkjkfa7.jpg
Next up was the new check valve install between the manifold and the oil seperator, figured that whilst I am busy let’s replace the PCV, what a ball ache, just couldn’t get that sucker off and had to pull the intake manifold which remind me, forgot to mentioned that I also had a CC done about 180 miles prior to the Stage 1 install.
Damn, almost midnight down here so it’s way past my bedtime, been a long day, will pick it up again tomorrow.
Goodnight everyone.
