Ok, so as mentioned previously, with the dryer relocation behind me I could put the rest of the stuff back together and next on the list was the JHM oil cooler lines. The quality of these part is just top notch and much beefier than the OEM pipes and fittings. Nothing wrong with my OEM ones but decided to replace whilst in there as preventative maintenance.
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02357_zpsq7zuww3k.jpg
Install is straight forward and the only important thing here is to install the supplied bigger rubber stand-off to allow proper clearance between the new line and the steering fluid cooler.
Larger Fitting
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02363_zpse0rxrakv.jpg
Perfect Gap
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02365_zpsxw6fmmoj.jpg
After the AC Dryer exercise this was a quick and easy job, here they are all fitted and torqued down.
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02369_zpsfhwbbatp.jpg
So as mentioned at the start I didn’t want to cover the complete install all over again, quite a few of you have been there done got the T-shirt so I am leaving most of the general stuff out and try to just show the few things I did differently. If there is anything in particular regarding the general install someone would like to know or see let me know.
So with that said the next thing on the list that I thought I would do differently was the MAF extender. The extender is shipped as a pigtail with a female plug on the one side to plug into the MAF sensor after it’s been relocated into the newly supplied JHM MAF adapter. The other end of the tail is, well just flapping around and the idea is to splice that into the OEM MAF harness.
Pig Tail
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/MAF%20Extender_zpsha10oq8y.jpg
I am sure that works well but I didn’t want to have to deal with that again in the future and was looking for a proper plug to fit to the pigtail end. Searched far and wide and couldn’t find a plug that would work so set about making my own. Eventually found what I was looking for, a 2nd hand MAF sensor from a B6 which is an exact match to the RS4 MAF.
The Circled piece is what I was interested in
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02381_2_zpskanpvgcc.jpg
I then cut away the rest of the sensor bit by bit until I was left with just the plug section and the copper pins at the back which used to be connected to the now removed circuit board. Got my tester out to identify the pins at the back and soldered each corresponding wire from the supplied MAF extender to the correct pin on the modified plug. Ended up with something like this.
The RUDEPLUG ;D
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02385_zpsm2ot6ktw.jpg
So, the battle was halfway won but the war wasn’t over! Wrecked my head on how to turn that contraption into a durable, heat-resistant waterproof plug and came up with this. Decided to use the plastic Cap from a milk container to act as mold
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02388_zpsjt5rwrxu.jpg
Fitted like a glove.
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02389_zps9cn8xq4p.jpg
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02390_zpsh6gbtwg3.jpg
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02391_zpslv5dyotp.jpg
Secured it with a Zip tie and poured some quick set resin into it
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02393_zpsark1eqq6.jpg
Left it for about an hour, removed the mold and this is what I ended up with. I was one happy camper, worked out great and was exactly what I was aiming for.
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02395_zps8xp59occ.jpg
Could now plug it securely into the OEM MAF harness with no chance of that puppy coming loose whilst having fun.
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/DSC02394_zpskuxtfnto.jpg
With that obstacle out of the way the MAF extender was plugged into its resting place in the engine bay and I turned my attention to check and secure all the clamps on the intake, booster and spider pipes. I was getting close and could see the light at the end of the tunnel so to speak, just hope that light wasn’t a train coming my way.
