Vagcom scan
Thursday,14,February,2013,22:29:27:43859
VCDS Version: Release 11.11.5
Data version: 20121222
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
VIN: WAUXU54B42N120625 Mileage: 323520km/201026miles
Address 01: Engine Labels: None
Part No: 4D0 907 559 B
Component: 4.2L V8/5V G 0001
Coding: 06752
Shop #: WSC 02325
VCID: 2D5FF51EE7BA6D70BAA
WAUXU54B42N120625 AUZ7Z0A2023706
3 Faults Found:
17539 - Oxygen (Lambda) Sensor; B2 S1
P1131 - 35-10 - Internal Resistance too High - Intermittent
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 35-00 -
17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
P1296 - 35-00 -
Readiness: 0000 0101
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4B0 927 156 EQ
Component: AG5 01L 4.2l5V USA 1010
Coding: 01002
Shop #: WSC 02325
VCID: 7AF50E4266740AC86F8
1 Fault Found:
17114 - Gear Ratio Monitoring
P0730 - 35-00 - Incorrect Gear Ratio
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 AA
Component: ABS/ESP allrad 2329
Coding: 06397
Shop #: WSC 00000
VCID: 60C15C2AE0E8F01841C
1 Fault Found:
01119 - Gear Recognition Signal
35-10 - - - Intermittent
Address 06: Seat Mem. Pass Labels: None
Part No: 4B0 959 760 C
Component: Sitzmemory R1 BF 0103
Coding: 00003
Shop #: WSC 00000
No fault code found.
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AD
Component: A6-Klimavollautomat 0105
Coding: 00000
Shop #: WSC 02325
VCID: 5CB968DACC80D4F81D4
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4B0 959 655 N
Component: Airbag 8.4E 5001
Coding: 0000407
Shop #: WSC 02325 785 00200
VCID: 3B7BCB4679CEF3C034E
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 933 T
Component: KOMBI+WEGFAHRS. VDO D09
Coding: 03383
Shop #: WSC 93187
VCID: 3469E07A04903CB8F54
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D35
Coding: 15885
Shop #: WSC 93187
VCID: 3061EC6AF088009891C
7 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver’s Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00956 - Key 2
09-10 - Adaptation Limit Surpassed - Intermittent
00957 - Key 3
09-00 - Adaptation Limit Surpassed
01561 - Left Rear Door
59-00 - Can’t Unlock
01562 - Right Rear Door
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0102
Coding: 00001
Shop #: WSC 00000
VCID: 2C59F81ADCA06478AD4
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00102
Shop #: WSC 93187
VCID: 264D0A32C24C5E287B0
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00050
Shop #: WSC 02325
VCID: 040970BA14B04C38054
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 4B0 035 195 L
Component: symphony II NP2 0051
Coding: 00201
Shop #: WSC 00003
VCID: 2957010ED3527150562
1 Fault Found:
01336 - Data Bus for Comfort System
49-10 - No Communications - Intermittent
End ---------------------------------------------------------------------
