Sounds awesome !!! Nice work
Sounds great. So where are the flaps and how are you controlling?
Thanks.
Its on second page, button isn’t automatic, click and holding for open and close
so, after about 400km of driving, no CEL. but, today i get airbag light on after washing :-\
here is vcds scan faults
Monday,27,February,2017,18:06:29:46862
VCDS Version: Release 10.6.0
Data version: 20100630
Mileage: 199520km/123975miles
07-Control Head – Status: Malfunction 0010
15-Airbags – Status: Malfunction 0010
25-Immobilizer – Status: OK 0000
46-Central Conv. – Status: OK 0000
55-Xenon Range – Status: OK 0000
56-Radio – Status: OK 0000
57-TV Tuner – Status: OK 0000
61-Battery Regul. – Status: OK 0000
76-Park Assist – Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 4F1 910 552 C HW: 4F1 907 552
Component: 5.2L V10/4V FSI Ş0060
2 Faults Found
000345 - Oxygen (Lambda) Sensor B2 S2: Response too Slow
P0159 - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 6
Mileage: 199111 km
Time Indication: 0
Date: 2017.02.23
Time: 15:22:27
Freeze Frame:
RPM: 2791 /min
Load: 19.2 %
Speed: 58.0 km/h
Temperature: 99.0°C
Temperature: 21.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.970 V
P1923 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 199526 km
Time Indication: 0
Date: 2017.02.27
Time: 17:56:38
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 66.0°C
Temperature: 59.0°C
Voltage: 11.684 V
Readiness: 0000 0000
Address 11: Engine II Labels: None
1 Fault Found
012836 - Oxygen (Lambda) Sensor B3 S2: Signal too Slow
P3224 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 6
Mileage: 198958 km
Time Indication: 0
Date: 2017.02.15
Time: 10:31:47
Freeze Frame:
RPM: 1688 /min
Load: 25.1 %
Speed: 60.0 km/h
Temperature: 100.0°C
Temperature: 27.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 42 AIRBAG AUDI8RH30 0280
1 Fault Found
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
014 - Defective - Intermittent - MIL ON
Latest upgrade, 8pot callipers & 380mm discs
Pics
https://uploads.tapatalk-cdn.com/20180307/5caf3993ce067aea685b8db293351680.jpg
https://uploads.tapatalk-cdn.com/20180307/f1474c64ad19da98a0e78ef7fdaba750.jpg
https://uploads.tapatalk-cdn.com/20180307/9e1c1edc3ad608e668c41bcda000d5be.jpg
https://uploads.tapatalk-cdn.com/20180307/4b3e42f8f98681a032248b77e308d299.jpg
https://uploads.tapatalk-cdn.com/20180307/1dab0994256562e47a0a027d590a43b2.jpg
https://uploads.tapatalk-cdn.com/20180307/b1c5fc5353fed5ff06d98d0b54378048.jpg
https://uploads.tapatalk-cdn.com/20180307/30108b6d1ecfe52fd6c20b6d8ec852c3.jpg
https://uploads.tapatalk-cdn.com/20180307/c1ced36888784c3fc021002f0dbd47e0.jpg
https://uploads.tapatalk-cdn.com/20180307/9a0cb7442abfe024f98be5a38b608082.jpg
Poslano sa mog LAVA_R1s koristeći Tapatalk
NICE!
Which brake is that? RS6?
I’m looking to upgrade mine.
Same like this on link, https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F331095808885
Only adjustment was to make central adapter ring, drill new holes for whel bolts, on caliper carrier cut off 3mm to get caliper on centre of disc, and adapter bushing for smaller bolts
https://uploads.tapatalk-cdn.com/20180308/c49a6c3dd696884ab544c98c08da87e0.jpg
https://uploads.tapatalk-cdn.com/20180308/2e712281c27a1a13b112f6d63792cefe.jpg
https://uploads.tapatalk-cdn.com/20180308/dd3f1287253595469071ceab9845e084.jpg
https://uploads.tapatalk-cdn.com/20180308/36bdd53c25c3d846802d457ca84a7214.jpg
WOW that’s a big chunk of change. It looks great but for that amount of money you hate to have to modify it to fit still.
Overall tho it looks great.
Awesome.
That’s good info. Reminds me of when I did the Cayenne/Touareg 18z swap on my B6 S4, had to run the JHM bolts and bushings to make it work.
I was looking at Brembos GT kit for the A6 4.2. It’s a 6pot caliper with 380x32 rotors. Just hope the A6 uprights are the same as the S6
If I pull the trigger I’ll post up here.
day one…
http://audirevolution.net/addons/albums/images/952530409.jpeg
http://audirevolution.net/addons/albums/images/214770101.jpeg
Nice. Cant wait to do this to my car.
Have fun! Lots of work ahead but it is worth it.
wowwwww you are brave!! :o :o :o
can’t wait to see more updates!
Its scary seeing the motor like that. But it looks like your off to a good start.
And here it is
https://uploads.tapatalk-cdn.com/20180401/219cb97beffa8d26164685e5256de709.jpg
https://uploads.tapatalk-cdn.com/20180401/537e6fb3e13084c59652596f67e9a427.jpg
https://uploads.tapatalk-cdn.com/20180401/6f994c264ebeebef9818f0728d68b50b.jpg
https://uploads.tapatalk-cdn.com/20180401/8fc4808eb50ab49e52a783c50a612f07.jpg
YEAH BABY - THATS AWESOME, was it much to drop the engine that way? great to see another style of headers out there, equal length arent the only way…we need videos immediately!
Yeah It would be nice to see them equal length and I’m not too sure if there shot gunned in the collector as if you don’t have that done your loosing a big chunk of power. but even if they are just longer primaries into a collector that should help.
It will be interesting to see how the 02s react to the primaries like that.
Good to see the update coming along.
Driver side all o2 sensors give error. after using injector cleaning in fuel, so engine was needed to be dropt to replace them, also AC gas leaking somewhere. it was oportunity to try this set up and see results, after will go on dyno and maybe some tune up to make work smooth with this set up.
Headers cost me only 1650$ so if will be bad, no problem, easy to go on stock
Only $1650? I’m in to see where this goes. May want to get a set of those sometime down the line.
