Hello all. While driving down the road today, randomly I had EPC, TMS, Brake, and Check engine lights all come on at once.
Ran a scan from obdeleven and these were the results. The headlight and window regulator issues were pre-existing. The other 7 faults are new from whatever happened today. Car runs but barely. Idle is uneven reving up and down almost stalling. Any ideas?
Thanks in advance for any insight.
OBDeleven data log
Date: 2020-05-21 14:29
VIN: WAUGN74F09N019457
Car: Audi S6
Year: 2009
Body type: Saloon
Engine: BXA 320 kW (435 HP) 5.2 l
Mileage: 205580 KM
01 Engine
Software number: 4F1910562A
Software version: 0010
Hardware number: 4F1907552B
Long coding: 01050009190F0160
Trouble codes:
P1653 - Read DTC memory of ABS CM Implausible signal
static
Priority: 2
Frequency counter: 1
Driving cycle: 255
Mileage: 205581 km
Date: 2020-05-21 14:23:15
P1923 - Check DTC memory of Engine Control Module (ECM) 2 Implausible signal
static
Priority: 2
Driving cycle: 255
Mileage: 205581 km
Date: 2020-05-21 14:23:16
02 Transmission
Software number: 4F5910156J
Software version: 0020
Hardware number: 09E927156C
Serial number: 0129737
Coding: 0000002
Trouble codes:
No trouble codes found
03 Brakes
Software number: 4F0910517AL
Software version: 0060
Hardware number: 4F0614517BA
Serial number: 00000000000000
Coding: 0020920
Trouble codes:
01314 - Engine control module (ECM) Please read DTC
static
Priority: 3
Frequency counter: 3
Driving cycle: 203
Mileage: 205581 km
04 Steering Angle Sensor
Trouble codes:
05 Keyless System
System description: FBSAUDIC6 ELV H05
Software number: 4F0910852B
Software version: 0100
Hardware number: 4F0905852E
Hardware version: 242
Serial number: 10602501224309
Coding: 0000007
Subsystems:
System description: FBSAUDIC6 EZS H03
Software number: 4F0910132L
System description: FBSAUDIC6 KSG H03
Software number: 4F0910335B
System description: FBSAUDIC6 IDG H01
Software number: 4F0910220G
Software version: 0040
Trouble codes:
07 Display
System description: Interfacebox H43
Software number: 4F0910732R
Software version: 4610
Hardware number: 4E0035729A
Serial number: 361JV087525246
Coding: 0010003
Subsystems:
System description: Bedienteil MMIC6H01
Software number: 4F0910609E
Trouble codes:
08 Air Conditioning
Software number: 4F0910043A
Hardware number: 4F1820043AG
Serial number: 00000030400840
Coding: 0524330
Trouble codes:
09 Central Electrics
System description: ILM Fahrer H22
Software number: 4F0910279M
Software version: 0320
Hardware number: 4F0907279A
Serial number: 4F0907279
Coding: 0135122
Subsystems:
System description: Wischer AudiC6 H10
Software number: 4F1910113D
Coding: 0056595
System description: REGENLICHTSENSORH04
Software number: 8K0910557
Software version: 0003
Coding: 0146221
Trouble codes:
02747 - Bixenon Switch-off Solenoid Switch, right Open circuit
static
Priority: 2
Driving cycle: 203
Mileage: 203560 km
Date: 2020-04-25 18:40:00
0E Media Player
Software number: 4E0910110E
Software version: 0390
Hardware number: 4E0035110A
Hardware version: 000
Serial number: AUZ5ZBH8644340
Trouble codes:
0F Digital Radio
Software number: 4E0910593M
Software version: 0160
Hardware number: 4E0035593F
Serial number: AUZ4Z7H0443391
Coding: 0000100
Trouble codes:
02635 - Tuner not enabled/activated
static
Priority: 7
Driving cycle: 158
Mileage: 204158 km
Date: 2020-04-30 13:08:02
11 Engine 2
Trouble codes:
P3028 - Throttle drive 2 angle sensor 2 Implausible signal Implausible signal
static
Priority: 2
Driving cycle: 255
Mileage: 205581 km
static
Priority: 2
Driving cycle: 255
Mileage: 205581 km
15 Airbag
System description: Airbag AU1042
Software number: 4F0910655M
Software version: 0090
Hardware number: 4F0959655F
Hardware version: H06
Serial number: 003000000000
ODX name: EV_Airba10AURB4
ODX version: 001001
Long coding: 303142373034303030394A55304C34463053
Subsystems:
System description: BF-Gewichtss.
Software number: 4F0910339B
Hardware version: H03
Serial number: 5810000R0000002TTE
Long coding: 000000
Trouble codes:
16 Steering Column
System description: J0527
Software number: 4F0910549A
Software version: 0410
Hardware number: 4F0953549D
Serial number: 90055082810167
Coding: 0012141
Subsystems:
System description: E0221 H02
Software number: XXXXXXXXXXX
Software version: 0030
Trouble codes:
17 Dashboard
System description: KOMBIINSTR.
Software number: 4F0920982K
Software version: 0133
Hardware number: 4F0920982K
Serial number: 9GF24HNA8
Long coding: 839F0A010B00CF05020201
Trouble codes:
19 Gateway
System description: GW-BEM 5CAN-M
Software number: 4F0907468G
Software version: 0024
Hardware number: 4F0907468G
Serial number: 2200M0892380F4
Long coding: 000303
Subsystems:
System description: J367-BDM
Software number: 8K0915181C
Hardware version: H07
Serial number: 00000000002730291344
Trouble codes:
1E Media Player 2
System description: SG ext.Player
Software number: 4E0035785F
Software version: 0850
Hardware number: 4E0035785C
Hardware version: H15
Long coding: 010000
Trouble codes:
36 Driver Seat
System description: MEM-FS
Software number: 4F0959760C
Software version: 0062
Hardware number: 4F0959760C
Hardware version: H08
Serial number: 00001001173532
Long coding: 00581B00004011110000
Trouble codes:
37 Navigation
Software number: 4E0910888M
Software version: 1100
Hardware number: 4E0919887M
Serial number: 395JR087530230
Trouble codes:
3C Lane Change Assistant Right
System description: J0769_SWA_MasterH02
Software number: 4L0910566D
Hardware number: 4L0907566B
Serial number: 6PZ 009 014-15
Coding: 0000002
Subsystems:
System description: J0770_SWA_Slave_H01
Software number: 4L0910568D
Trouble codes:
42 Driver Door
System description: TSG FA
Software number: 4F0959793R
Software version: 0250
Hardware number: 8K0959793D
Hardware version: H11
Serial number: 0000100406467
Long coding: 011F57205E40410001
Trouble codes:
02115 - Lock unit for central locking Implausible signal
static
Priority: 3
Frequency counter: 46
Driving cycle: 203
Mileage: 202365 km
Date: 2020-04-05 18:47:05
46 Comfort System
System description: Komfortgeraet H28
Software number: 4F0910289N
Software version: 0240
Hardware number: 4F0907289N
Serial number: 01152962600000
Coding: 4618397
Subsystems:
System description: LIN BACKUP HORN H03
Software number: 1K0951605C
Software version: 1301
Trouble codes:
01134 - Alarm horn Electrical error in circuit
static
Priority: 3
Frequency counter: 254
Driving cycle: 203
Mileage: 193723 km
Date: 2019-11-13 08:07:51
47 Sound System
Software number: 4F0910223J
Hardware number: 4F0035223G
Serial number: 00000000123858
Coding: 0000026
Trouble codes:
4C Tire Pressure
Software number: 4F0910274A
Hardware number: 4F0907274
Serial number: 00008390037518
Coding: 0623333
Trouble codes:
01316 - Brake control module Please read DTC
static
Priority: 3
Driving cycle: 203
Mileage: 205581 km
Date: 2020-05-21 14:23:18
4F Central Electrics 2
Software number: 4F0910280
Hardware number: 4F0907280C
Hardware version: —
Serial number: 00000000248293
Coding: 0012014
Trouble codes:
52 Passenger Door
System description: TSG BF
Software number: 4F0959792R
Hardware number: 8K0959792D
Serial number: 0000100413441
Trouble codes:
53 Parking Brake
Software number: 4F0910801D
Hardware number: 4F0907801B
Coding: 0008021
Trouble codes:
55 Headlight Regulation
System description: AFS 1 H01
Software number: 4L0910357
Hardware number: 4L0907357
Coding: 0000016
Subsystems:
System description: AFS-Modul links H01
Software number: 4F0941329D
System description: AFS-Modul rechtsH01
Trouble codes:
56 Radio
Software number: 4E0910541T
Software version: 0630
Hardware number: 4F0035541N
Serial number: 379JW087542005
Coding: 0000002
Trouble codes:
62 Rear Left Door
System description: TSG HL
Software number: 4F0959795M
Software version: 0251
Hardware number: 8K0959795B
Hardware version: H10
Serial number: 0000100393104
Long coding: 010E57204040220001
Trouble codes:
02110 - Window regulator switch Implausible signal
Intermittent
Priority: 3
Driving cycle: 231
Mileage: 205306 km
Date: 2020-05-16 19:22:23
67 Voice Control
Software number: 4E0910754Q
Hardware number: 4E0035753A
Serial number: 00000810140273
Trouble codes:
6C Rear View Camera
Software number: 4F0910441D
Hardware number: 4L0907441B
Serial number: 525PA8-J8X20S6
Coding: 1000204
Trouble codes:
72 Rear Right Door
System description: TSG HR
Serial number: 0000100398107
Trouble codes:
77 Telephone
Software number: 4F0910336H
Software version: 1130
Hardware number: 4E0862335
Serial number: 00000005066846
Coding: 0010900
Trouble codes:
No trouble codes found.
