Recently I’ve been getting an intermittent EPC/limp mode fault that happens maybe once every 100km/10 starts. Here are the collection of codes that pop up over the course of multiple scans:
(2020):
- P0221 - Throttle Position Sensor B (G188), Circuit Range / Performance
- P1564 - Throttle Actuator (J338), Under-Voltage during Basic Setting
- P0023 - “B” Camshaft Position - Actuator Circuit/Open Bank 2
- P0024 - “B” Camshaft Position - Timing Over-Advanced or System Performance Bank 2
- P1060 - Bank 2, cam shaft adjustment discharge opening, interruption
Coincidentally, I had no problems until immediately after I used some RTV to seal a leak/whistling sound from passenger TB to the Y-intake. This was at the lower front bolt holding right next to the TB electrical connector. (see: Whistling at idle). The RTV has since been replaced by a new TB gasket (although the old one looked fine).
The same codes popped up 3 years ago, at which time I believe the TB and cam solenoid valve were tested by my mechanic with a 12V battery and seemed to be operating correctly. He cleaned the electrical connectors a couple times, and also added a zip tie to secure the TB electrical connector because I believe a clip was broken. That seemed to fix the problem until now.
(2017)
- P2101 - Throttle Actuator “A” Control Motor Circuit Range/Performance
- P2106 - Throttle Actuator Control System - Forced Limited Power
- P0024 - Camshaft Position Actuator B Bank 2, Timing Over-Advanced
- P1545 - Throttle Valve Controller, Malfunction
The problem is intermittent, and during this covid19 lockdown, I can’t seem to trigger it on short drives. But is there anything else I can do to diagnose this problem with certainty?
Also, can someone confirm the location of Throttle Position Sensor B (G188), Throttle Actuator (J338), and “B” Camshaft Position?
