What’s up fellas, thought I’d share some stuff as I go through my build. I go by s4orgy on audizine. Owned two b5 2.8s before finally getting my hands on my dream car. Got it back in 2012 with 67k miles on it. Great story behind this car and how I got it but skip all that. First Mod was full exhaust. I bought a set of 2.5 a.w.e downpipes off of a member and gutted them. I Chose to “reinvent the wheel” as euroswagr would say/;D by building my own corsa exhaust instead of getting f.i. or magnaflow.http://www.audizine.com/forum/showthread.php/507879-LOoky-Here. When the guy at that exhaust shop staryed my car i could remember saying to myself was “holy sh!t is that my car”. Car felt like it was being choked out by the cats. Night and day difference performance wise compared to stock. But being catless the car seemed a little laggy down in the lower rpms. I then wanted to get rid of of the CEL so I went out and got my car tuned @ High Fidelity Auto Sport/shout-out to marc. Months later my camshaft needed to be replaced so I picked up a used cylinder head with low miles just to swap camshafts. During that time I bought 034’s engine mounts/track density, apikol snub mount/Track density, vcover gaskets.@ Around 85k miles or so I replaced all plugs with new ngk platinum plugs,all new coil packs from audi, new rear o2 sensors. Now I will be adding all of this to my car:
New Starter.
http://i1132.photobucket.com/albums/m565/ashezaaron/20150307_184631_zpsvpvvhii1.jpg
Stern adjustable upper control arms.
http://i1132.photobucket.com/albums/m565/ashezaaron/IMG_20150307_191015_zpsut4wdxsi.jpg
Purchased from a member on audizine.
Front & Rear Crank Seal.
http://i1132.photobucket.com/albums/m565/ashezaaron/Mobile%20Uploads/20150307_180341_zpsgwm4iuul.jpg
JHM Auto-Belt Tensioner Kit.
http://i1132.photobucket.com/albums/m565/ashezaaron/Mobile%20Uploads/20150307_180435_zpsabrvwaez.jpg
Oil check valve kit w/(4) intake spacers.
http://i1132.photobucket.com/albums/m565/ashezaaron/20150307_183222_zpsuq7i2an4.jpg
Apikol Transmission Mount/Track Density .
http://i1132.photobucket.com/albums/m565/ashezaaron/20150307_180550_zpsohoxao77.jpg
Valve stem Seals.
http://i1132.photobucket.com/albums/m565/ashezaaron/20150307_192352_zpsfthbzxow.jpg
All New Tensioners/Guides.
http://i1132.photobucket.com/albums/m565/ashezaaron/20150307_181346_zpswo5zau5a.jpg
JHM Cam-Adjuster Sprockets.
http://i1132.photobucket.com/albums/m565/ashezaaron/IMG_20150307_190435_zpstw9bemrc.jpg
JHM Lightweight Pulley.
http://i1132.photobucket.com/albums/m565/ashezaaron/20150307_182312_zpsg31inpnu.jpg
JHM stage 3 clutch/Lightweight Flywheel.
http://i1132.photobucket.com/albums/m565/ashezaaron/Mobile%20Uploads/20150307_182101_zpszrsiuqqd.jpg
JHM Ported Intake Manifold w/Ported elbow. & spacers.
http://i1132.photobucket.com/albums/m565/ashezaaron/IMG_20150307_190726_zpsexb1htgq.jpg
http://i1132.photobucket.com/albums/m565/ashezaaron/IMG_20150307_190918_zpsndcy05b7.jpg
