Its a Audi RTV type of sealent no gaskets.
Check your oil drain plug and your valve cover gaskets. They are the major sorce of issues.
The lower oil pan could be an issue but its not very common
The valve covers looked fine when I had the intake off so I don’t think it is them. I suck my oil out of the dip stick so haven’t ever had the drain plug out but will check that.
The oil from the valve covers generally runs down the side of the block on the outside. The removal of the intake wont show you much in that.
The pcv system can also be leaky enough to cause issues there too. Check the drain plug. Its something that can happen over time
So i now havea purge valve check engine light on and a high pitched squeal coming from the valve. Does that mean my valve is bad?
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E0 910 552 A HW: 4E0 907 552
Component: 5.2L V10/4V FSI ª0040
Revision: 5AH11— Serial number: AUX3Z0F9709393
Coding: 01060009190F0160
Shop #: WSC 02120 444 92496
VCID: A045A51B7352D63ECB-80F4
1 Fault Found:
001092 - EVAP Purge Control Valve (N80)
P0444 - 004 - Circuit Open - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 156223 km
Time Indication: 0
Date: 2015.12.01
Time: 13:45:29
Freeze Frame:
RPM: 2212 /min
Load: 32.1 %
Speed: 0.0 km/h
Temperature: 6.0°C
Temperature: 9.0°C
Absolute Pres.: 960.0 mbar
Voltage: 10.287 V
Readiness: 0000 0000
Great job posting the codes. Always helpful when you can do that.
You have 5 codes for the control valve. That isnt a good sign. That and the symptoms your having seem to all point to the same thing.
Well it seemed to have fixed itself. No engine light or squeal so I’ll keep an eye on it but right now all good
might have been just cold temps and the valve sticking
was curious on when someone should replace the fuel filter. Looking online they as relatively cheap and easy to replace. I’m at 95k and don’t know if it had ever been replaced.
You should replace it. I do mine roughly every 50k miles.
The maintenance cycle we used to try to follow was every 30k miles for fuel filter, 15k for spark plugs, 50k for coil packs, 5k for oil/filter, 5k for air filter. Or thereabouts.
The way I see it following the audi cycle for example you do plugs every 50k miles or so. That’s every 3-4 years. If you do it every year over the course of 4 years you’ve added $400.
Fuel filter every 2 years you add 200 over 4 years (I think audi has it lifetime???)
Oil every 5k vs 10k adds about $400 over 4 years
Doing coils every 50k (audi says lifetime) adds 200 every 4 years.
After 4 years and 50,000 miles or so you’ve added a total of $1200
$300/year is the difference for always tip top engine maintenance. That’s peanuts. We are talking about cars that were $50,000 to $80,000 when new.
I work under the rule. If you dont know when it was last replaced its best to replace it. given its not too much money and its not too hard to replace. It is a good thing to do.
Here is a good list to follow
alright alright, fuel filter ordered and air filters as well.
does anyone have any issues with their backup camera? Mine seems to be hit or miss on when it wants to turn on. It has been about 0° out lately. I know I need to scan to see if any codes come up but none did before.
Thoughts?
Here is my scan: I cleared them and rescanned. All that came back was the navigation malfunction. I didn’t drive the car around so tomorrow I’ll see if the others come back.
Saturday,16,January,2016,20:59:02:37301
VCDS – Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
Ross-Tech: Home
VIN: WAUPN44E57N011549 License Plate:
Mileage: 157880km-98102mi Repair Order: 858
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 19 1E 34 36 37
38 42 46 47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUPN44E57N011549 Mileage: 157880km-98102miles
01-Engine – Status: OK 0000
06-Seat Mem. Pass – Status: OK 0000
07-Control Head – Status: Malfunction 0010
0F-Digital Radio – Status: OK 0000
11-Engine II – Status: OK 0000
31-Engine other – Status: OK 0000
15-Airbags – Status: OK 0000
19-CAN Gateway – Status: Malfunction 0010
1E-Media Player 2 – Status: Cannot be reached 1100
34-Level Control – Status: Malfunction 0010
37-Navigation – Status: Malfunction 0010
38-Roof Electronics – Status: OK 0000
46-Central Conv. – Status: OK 0000
55-Headlight Range – Status: OK 0000
56-Radio – Status: OK 0000
61-Battery Regul. – Status: Malfunction 0010
65-Tire Pressure – Status: Malfunction 0010
6C-Back-up Cam. – Status: Malfunction 0010
76-Park Assist – Status: Malfunction 1010
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 T HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 348JX067508352
Coding: 0000003
Shop #: WSC 02313 785 00200
VCID: B36F5A57D2A45DA626-80E6
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Subsystem 2 - Serial number: 00000000025669
Subsystem 3 - Serial number: 0117.11.060000000100010136ÿ
Subsystem 4 - Serial number: 010136ÿ
1 Fault Found:
01327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 88
Reset counter: 215
Mileage: 156438 km
Time Indication: 0
Date: 2015.12.07
Time: 08:27:33
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B06A298160
Coding: F5D5DFFF707A0E
Shop #: WSC 02120 444 12486
VCID: ECDD812BCF1AC25E27-80B8
2 Faults Found:
02077 - Media Player Position 2 (R119)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 94
Mileage: 156365 km
Time Indication: 0
Date: 2015.12.04
Time: 21:20:35
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 215
Mileage: 156365 km
Time Indication: 0
Date: 2015.12.05
Time: 08:05:30
Address 1E: Media Player 2
Cannot be reached
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
VCID: AA514733056E1C6E95-80FE
1 Fault Found:
01398 - Signal Conductor for Central Locking; Doors Open
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 203
Mileage: 157655 km
Time Indication: 0
Date: 2016.01.12
Time: 19:32:51
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 L
Component: MNS US H48 1100
Revision: 00000000 Serial number: 381J.067509772
Shop #: WSC 02120 444 59879
VCID: B8756D7BCBC2BEFE13-80EC
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 255
Reset counter: 215
Mileage: 156366 km
Time Indication: 0
Date: 2015.12.05
Time: 08:14:52
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000022512
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 321109907S
Coding: 344530393135313035412056413033323131303939303753
Shop #: WSC 42540 000 1048576
5 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 6
Reset counter: 255
Mileage: 157611 km
Time Indication: 0
Date: 2016.01.11
Time: 16:32:39
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Time Indication: 0
Date: 2016.01.11
Time: 17:18:41
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 157626 km
Time Indication: 0
Date: 2016.01.11
Time: 17:19:27
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 157626 km
Time Indication: 0
Date: 2016.01.11
Time: 17:19:37
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 157626 km
Time Indication: 0
Date: 2016.01.11
Time: 17:19:47
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12— Serial number: 525PA8-J6910QS
Coding: 1121402
VCID: DCBDD1EB1FBAB2DED7-8088
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 215
Mileage: 156365 km
Time Indication: 0
Date: 2015.12.05
Time: 08:05:30
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08730630406850
Coding: 0221208
VCID: A34FAA176244CD26D6-80F6
2 Faults Found:
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 197
Mileage: 157549 km
Time Indication: 0
Date: 2016.01.08
Time: 20:44:07
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 198
Mileage: 157141 km
Time Indication: 0
Date: 2015.12.30
Time: 12:53:53
Thoughts?
You can see there is a malfunction in the system. It dosent seem to link or show anything specific on the fault. The code looks like a general malfunction. You said it will work some times and not others is that right
Yes that is correct. Yesterday it worked in the morning then decided to not work anymore. Today it has been fine.
To troubble shoot this. keep an eye on the temp and how long you key the car up for before starting. Dont just get into the car and start it up. Get in hit the start butting to wake the car up but dont start it till the gauges WOW after that start it up and see if that helps the amount of times the system works
So I’ve noticed that it doesn’t like being put into reverse without all the gadgets being warned up. It is going to be around 0°F this weekend so I’ll keep an eye out and rescan as it had done it but not as frequent.
I put in led license plate lights from ecs.
Comparison:
http://uploads.tapatalk-cdn.com/20160213/ef5131aaf786c23c4ae2e041d5081f18.jpg
Both sides installed:
http://uploads.tapatalk-cdn.com/20160213/a7af5727f60cca027feb6fcfb35fdc64.jpg
Output is a huge difference and I’m happy with them.
I also ordered stainless steel screws as the oem ones suckand strip all the time.
