New guy
Looks good. I assumed they were led from the factory.
Nope they were regular incandescent bulbs.
Wow that really looks great. Would you mind making a quick post about that with part numbers. I might want to try that on my S4. That looks great.
Do you get codes for it or just when its cold. I dont know if I could put up with a light code on my dash. I tracked down a light bulb issue in one of may tail lights and it drove me crazy. I wouldnt want to go through that again
So trying to keep one thread for my car… I’ve noticed that my fuel gauge in the car will only go to 3/4 th’s full after a complete fill up. After a drive to work it will usually then show full. Is there an adaptation or something I can do in vcds to have it be full?
Or is something else going on inside the tank?
It has just started in the last two fill ups.
Do you fill the car with the car running. Usually the car needs to be off and then in key up but not started for the sending unit to find its proper adaption point.
No car is always off. Maybe I’ll try and turn it on but not over and see what it does
Ok so I replaced my oil separator back in March. I again have a high pitch noise coming from my engine, vacuum issues when pulling the oil cap off and most recently a low oil light came on. I change my oil every 5k and it is 2500 miles into the change. First time I’ve ever had to add oil between changes. Does the oil separator consume oil?
