From experience here are a few things I feel you should really consider.
The JHM units hands down are the best way to go and not just for the money.
keep this in mind. NEW OEM injectors that came in our car obviously fail…this is why we even need to replace them. If you look along the Carfax route of 5.2 motors they all have injector issues. Some as few a 30k miles.
Now did those injectors go bad right at 30k miles or even 100k miles when its so bad you notice that there are issues… obviously not. The injectors start going bad but you only notice it once its so bad the car misfires or just runs terrible.
getting “NEW” oem injectors are not Audi new they are just the same platform of injector but not built to the same specs that Audi requires. Take some time and just search how there is a major difference between parts with the same platform and Audi or BMW or GM or Ford specific injectors built on that platform or even 02 sensors.
This idea of getting “new” injectors still has shown no consistency and even several batches of “new” injectors the rs4 guys got and tested have shown to flow all over the map.
With JHM your paying for injectors that have been serviced and flow matched. The injectors have already been broken in due to them being in service already. This alone is a big deal.
IMHO if you just want new injectors then buy the cheapest injector you can find. But if your goal is to make sure you have good injectors that flow the correct amount and are all balanced and tuned there is a clear choice. For me knowing what I’m getting is the most important thing.
When you see big hp motors that a blown or burnt down you will notice its always one cylinder with a melted piston and that is generally the cause of a downed injector. Now is the 5.2 making sooo much power that your going to see huge issues like that… no… But over the past year or so all the 5.2 cars I have looked at have all shown low compression on cylinders with low flowing injctors due to damage.
