I’ve had the TCU tune for two weeks, and have found nothing but improvements in overall driveability and increased performance. So you know where I’'m at, I am running JHM tune, LW balancer, LW front rotors and JHM exhaust. I’ll start from the beginning. I think it was much simpler than when i did the ECU tune, and a whole lot faster. I did run into kind of an odd issue though. Apparently, my TCU had a very old box code (0010) which had some bugs/communication issues, this should have been updated by the dealer early on during a scheduled maintenance. So much for dealerships.
It’s a bit of a long story, but in the end what i gained from it was a great respect for JHM support. About 30% into flashing the TCU, everything halted, i gave it about 15 minutes, but nothing. Repeated the flashing steps a second time, and the same result. it was a Sunday early evening, but i sent an email to tech support, figuring i would hear from someone on Monday, to my surprise, i got a response almost immediately. In the end, I was up and running Monday. If anyone ever has any doubt about JHM’s commitment to their customers, I’m here to say that they are enthusiasts at heart, and stand by and support their product like no one else.
Now for the fun part- after the flash. Immediately, normal driving is improved with much smoother, more positive shifting at any speed. That holds true right up to about 50-75% throttle, at which point it is very obvious the shifting is quicker and firmer both up and down. Then, the full throttle experience- the first time it caught me a bit unprepared and the 1-2 shift had my head bounce off of the seat, I did that laugh out loud thing with a big smile. I did this a few time before i could satisfy my excitement. The things that stand out most are full throttle downshifts at highway speeds when passing are super quick compared to stock, and watching the tach during shifts tells how much faster the car shifts. Pull in higher gears seems much stronger. All of that is mostly seat of the pants, but i will be heading to the track to get some 1/4 mile times in. i have an old video of the speedo/tach during a 1/4 mile run, i’ll do another to compare shift times. i would have to gues it’s at least half the time to complete a shift, easily.
Anyway, if you are deciding, go for it. I don’t see how you could be disappointed. Maybe check your box code first, I think it the new code is 0030, but I’m not 100% sure.
That’s it for now, it time for carbon clean/new injectors and looking at LTFT’s- 3 banks at or right around 0, but bank 4 is 7-10%. I’ll recheck after carbon clean and new injectors.
