After reading not too long ago that the two of the b5 s4 records was acheved by the use of nitrous * 1 was aka the 10sec scam aritst used a 175shot on his gutted ko4 car to barely go 10’s claming he was all motor then the next and probably the most disturbing is a low rent shop AMD using nitrous to acheve better results to try and pimp there failed tial turbos * ill make my own post on that later
Still the thought comes to mind maybe with all the junk turbo gimmics out there for The b5. Maybe Nitrous is the best mod for the car… This would be couppled with a usfull turbo like a ko4 or a rs6
Let’s face it a ko4 or a Rs6 turbo b5 can be impressive for everyday driving and performance. A well tuned rs6 turbo car can do low 500whp but the most live I’m the mid to high 400 range. To jump from 450 to say 550 your going to need Gt turbos. Let’s face it the tials are a joke and not even a real option other then there cheap. Still even with a solid gt turbo your lag and real world power range gets shifted super high in the rpm range
That being said is a true notrous system the next best possible mod for The b5
I thought he was joking turns out that was exactly what he wanted to do… The owner went on to tell le how fast his car is once he hits 70 or so… Am I the only one that sees that at a pethetic joke thinking that building a car for going fast after 70 is. Quality that I would specificly build
