For race cars and off road use only.
I’m done with phase one of my PCV elimination experiment. Taking a broke PCV, I separated the base plate from the upper portion of the valve using a cutoff wheel. It’ll be scanned and then duplicated in solid form with no voids for air to pass through to seal off the PCV.
It’s a bit complicated to completely seal off the the PCV so I thought the re-engineered “plate” would be best. Will retain the o-ring to seal everything off just like factory.
Should have those in a couple of weeks tops along with a complete kit. This is better, IMO, than running a dual catch can setup which’ll be expensive and won’t prevent all the volatiles from entering the intake.
The downside of venting to atmosphere is that you may smell oil occasionally. I’ll be testing that side of things here soon. I’ll have a few photos up later so you can see what I’m referring to.
