Tsivas, What DA for those #'s? Are you using actual ambient hPa minus absolute hPa or just assuming 1,000 ambient hPa? Maybe I’m measuring the wrong field?
Saki, Just went and did a 4th gear pull in negative 500 DA per my weather station(can’t believe the strip isn’t open :’( ) I showed 16.987psi 4th gear at 6932rpm, fractional bypass so basically none… In these conditions assuming traction 11.6x is a layup… When I went 11.69 my peak measured boost was 16.389 in a 350 DA, so plus .6 psi today… wonder what that would do? In August of 2012, in a DA of 3300+ I saw 14.503psi and went 12.10… Pretty big difference… From Jeff’s logs when he and I raced, his peak boost number was 16.25 psi that day… I went 11.72 for a best that day so it makes sense IMO…
Peak Boost - 17.6 @ 6221 RPM
Peak Airflow - 1390 @ 7175 RPM (bypass valve open 20%!!! only 13.7psi) Errr, need to get this bypass valve CLOSED. If I was rocking 17 pounds at 7200 rpms the airflow would be over 1500 EASILY.
Peak Torque - 634 @ 6221 RPM
2nd Pass(same strip of road) - Light Spray of Meth
Starting Intake Temp - 41
Final Intake Temp at top of 4th -48
3rd Gear - Bypass opens @ 6273RPM
Peak Boost - 17.5 @ 4322RPM, 5402RPM, 6141RPM, 6432RPM, then bypass opens.
Peak Airflow - 1562kg/h @ 7197RPM (bypass open 18%!!! only 14.9 Psi) man if the bypass was closed on this run, 1600 kg/h EASILY. Meth clearly increases the VE and boost/airflow.
Peak Torque - 649Nm @ 6432RPM, 648Nm @ 5402RPM, and 647Nm @ 6273RPM
THAT would be interesting, to see related stock plot shape and turn it into a dyno as above.
According get to your numbers you’re making 567 hp at 7000. That’s probably not accurate as that would be about 480 who and that would see you trapping 122-123.
I am using the Nm reading from the engine torque calculation, then dividing it by 1.365 for the Nm to ft/lb torque conversion. How accurate it is, I do not know.
There are dyno plots out there for the 3.0 TFSI, I have seen them before. i am sure I could find one, doing schoolwork ATM.
