A lot probably depends on how you define desensitizing the knock sensors. I wouldn’t use that exact terminology, but in the most basic sense they are doing something along those lines, and fully admit it.
Per Revo’s Engineer/Calibrator (Robin):
The stock strategy is EXTREMELY conservative with how it responds to knock. When it picks up a little bit, it will pull out MUCH more timing than is necessary, creating higher EGTs and a sloppy curve. We modify the factory strategy in a way that keeps the factory safety routines in place, but changes the response loop so it will pull less timing and add it back in quicker. It’s not “turning off the knock sensors” as posted above.
The data also bares this out. If you are to believe what they are stating, it does seem logical, and at over a year in there have been no known issues with their approach. Back to the point made by the engineer that doesn’t trust engineers… I guess it depends on how much you want to trust the engineer/calibrator in this case.
